[COMPLETE] - Koa topped Strat with rosewood neck
13»
  • sweepysweepy Frets: 4192
    edited May 2017
    That's what I'd try tbh, it's one of those odd things, have you tried shimming the neck to increase the break angle at the bridge or the nut slot is too flat and not angled back a little
  • CorvusCorvus Frets: 2929
    An iffy nut slot can make buzz/sitar like noises, either a little burr or its not sloping down to the head end so the 'break' over the front edge isn't clean & crisp.
  • PVO_DavePVO_Dave Frets: 2376
    Thanks for the input! - having had a mess about with it, it's definitely nut related, pinging the string out and resting it on a flat part of the nut, no sitar type noise.
    Ive checked the depth of the slot compared to a couple of other guitars, it is quite high compared to those, I'll run a file through it again and try @Corvus 's suggestion of sloping it down a touch at the head end.
  • KalimnaKalimna Frets: 1542
    Possibly also adding a little pencil graphite into the slot to aid lubrication of the string?
    edited May 2017
    Thanks for the input @Kalimna @sweepy and @Corvus  - got the '10 nut file out, ran it through a few times and added a slight slope towards the headstock and the buzz / droning noise has gone D
    You learn something new every day
  • FelineGuitarsFelineGuitars Frets: 11619
    Yup - beat me to it . Nut slot needs to be higher at front edge than rear
    If not then the active bit of  thestring will not be sure of where it starts from and you'll get sitar like sounds.
    If it had been the bridge at fault you'd have buzz every note, so as it was only open then the nut is to blame as you found out.
    That's what we are here for, trust me, we all learn something when messing about with guitars ;)
    edited May 2017
    To get this back on track, to level the frets, I used the Wudtone fret levelling system, after getting the neck straight.
    Once level, I masked around the frets with 3M tape, used a Crimson fret file, followed by 1200 wet and dry, 0000 wire wool and a Crimson polishing rubber. The frets came out nice and shiny. Not a professional job, but the best one I've done so far.
    https://i.imgur.com/YUNUuAm.jpg
    https://i.imgur.com/AjTTmau.jpg
    Today, I deepened the nut slots and did all the wiring apart from the pickups
    https://i.imgur.com/jeX397d.jpg
    Waiting fir the pickups
    https://i.imgur.com/mDKygsz.jpg
    Next post should be the finished pictures D
  • impmannimpmann Frets: 12669
    Glad you got it fixed. Some good advice about the nut.
    edited June 2017
    Got a nice little delivery from Marc @ Mojo today D
    It lives!! Sounds great too. Tiny bit of tweaking to do to the setup, then proper photos and NGD post at the weekend. Very happy
  • paulnb57paulnb57 Frets: 3057
    That is a thing of great beauty, well done!
    aannnnnd done :D
    NGD thread here - thanks for looking and commentating :)
  • SargeSarge Frets: 2428
    Beautiful work, very impressive, well done that man!
  • ChalkyChalky Frets: 6811
    Well that looks pure class.
  • axisusaxisus Frets: 28341
    @PVO_Dave Out of the blue I just remembered this thread from last year. I never got to see how the guitar came out. Having just dropped by again, as expected, that is one awesome looking guitar! Right up with my very favourites that I have seen here. Great job!
    Thanks @axisus it's my favourite to play too :)
  • MLten80MLten80 Frets: 162
    stunning looks like a lipe or a penza or something equally as delicious
     top work
