DIY tips
Does anyone have any tips how I can stop sealant/adhesive cartidges drying out between useage?
 I'm redecorating my cloakroom at the moment but everytime I get a cartidge of silicon sealant I use about 5% of it and then it goes in the garage for "next time".  But every time I do this it dries out by the time I next need it next (which could be some a long time to be fair).   I'm just tired of throwing out nearly full cartridges.
cling film over the end?  Nail as a spingott?
  • randellarandella Frets: 4334
    Stick a long screw in the nozzle, keeps them for a bit longer but not forever.
    Interested to see if there are any more magic tips!
  • BigMonkaBigMonka Frets: 1784
    Some of the fancier tubes of sealant come with screw caps which help a bit.
    I saw something on facebook the other day about melting a bit of plastic milk bottle over the end, but it seemed too much like hard work to me! http://www.instructables.com/id/Resealing-Half-Used-Caulk-Tubes/
  • octatonicoctatonic Frets: 33863
    edited June 2017
    I put a plastic barrier over it- using plumbers tape and then jam the cap back on after that.
    It doesn't stop it completely but it is usually ok for one or two more uses.
  • breakstuffbreakstuff Frets: 10350
    edited June 2017
    Some tubes come with their own screw caps, but if they don't I usually seal it with a few wraps of electrical tape.If it does go off,it's usually only the silicon in the nozzle that sets and you can prize it out.
    Alternatively, when you buy a new tube,don't cut the nozzle and use one off an old tube.You can then use the new,uncut nozzel to seal the tube.
    Laugh, love, live, learn.
  • CorvusCorvus Frets: 2969
    I put masking tape over the end, hanging upside seems to help too. Less air in contact with the glop left in the spout. Still need to fish out the plug from the spout and doesn't make 'em last forever but does seem to help.
    One thing that can help is to remove the plastic nozzle and clean it out- put the tape over the main cartridge and then reattach the clean nozzle.
  • PolarityManPolarityMan Frets: 7306
    just find more things to seal
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • martmart Frets: 5205
    Run some sealant round the nozzle. ;)
  • Emp_FabEmp_Fab Frets: 24515
    @Flanging_Fred I can't believe you've asked that as I read the answer to that exact problem last week!!
    The solution is.... Vaseline.  When you're done sealing stuff, pull the plunger back a bit and hopefully the sealant will retract a bit in the nozzle, then push a cm or so of Vaseline down the end of the nozzle.  This keeps an airtight seal and the contents never dry out.  When you go to reuse it, just squeeze out the Vaseline until you get just sealant again and you're good to go.
    Works with all kinds of tube-based stuff that dries out apparently.
    Offset "(Emp) - a little heavy on the hyperbole."
    Haha! You're a bad man Mr Breakstuff.
  • sev112sev112 Frets: 2814
    Wooden kebab skewers - through the nozzle a sufficient length then break off
    next time take the cap/ nozzle off, mobilise the skewer again and bobs your uncle, nice open nozzle again, screw back on and off you go
  • Winny_PoohWinny_Pooh Frets: 7831
    ^ that's got to be more painful than Vaseline.
    Sick bastard
  • Flanging_FredFlanging_Fred Frets: 3108
    Oh wow.  Thanks chaps I'll certainly be giving some of these ideas a go.  The Vaseline idea sounds like it may have legs, also the plumbers tape (I assume PTFE stuff).  It just. So happens I have both in my guitar toolbox.
    Does anyone else have any other DIY tips to share? It could turn into a useful thread...
    Get someone else in to do it. :3
    I'm intrigued as to the reason for PTFE tape in your guitar toolbox?
    edited June 2017
    Wobbly trem arms. Put a bit around the thread tightens them up a bit. It also worked on a worn floyd rose stud thread.
  • snakemanStoosnakemanStoo Frets: 1708
    Mrs Stoo uses blu-tac.  She says it works well to seal the tube things.
    PSN id : snakey33stoo
    Yup.
  • equalsqlequalsql Frets: 6205
    Will KY Jelly work? B)
