Car air con condensation?
skunkwerxskunkwerx Frets: 6881
Usually quite knowledgable with cars, but none of the previous motors I've used have had working air con..
Current one does, but today after 30 mins of driving with the air con on full whack, I stopped to fill the tyres up with air and noticed a puddle and water running from underneath the car. Couldnt quite make out where it was coming from, but it was dripping from somewhere on the underside of the car, a bit behind the engine bay.
It seemed clear, not luminous green like the previous car pissed out after a failed air con refill.
Is that normal? Just condensation?
    Yes, that's normal. All my BMWs over the last 20 years did that .. :-)
  • JalapenoJalapeno Frets: 6399
    Yep, perfectly normal for a/c units to drip water.
    Feedback
  • AlnicoAlnico Frets: 4616
    Yep,
    My truck did that too.
    Totally normal.
  • tone1tone1 Frets: 5187
    Totally Normal  :)
  • mike_lmike_l Frets: 5700
    When t was green, that would be the dye used to find leaks.
    The water drip would just be the moisture taken from the air as the A/C was running, and nothing to worry about.
    If it was petrol/diesel then worry.
  • TitchTitch Frets: 45
    Normal.
  • ToneControlToneControl Frets: 11977
    it's the water that condensed onto the chillers from the air pumped in to cool you
    Sweet. I guess its all cool then!
    Cheers all.
  • RandallFlaggRandallFlagg Frets: 13959
    It's not normal. A puddle underneath you on a hot day means you have wet yourself you big baby.
  • Emp_FabEmp_Fab Frets: 24444
    Definitely not normal.  That sounds exactly like your bunion joint has burst and it's leaking friction fluid out of the crundle cylinder.  Until you can get it to a garage, the only option is to drive with the heater on full.  That will reduce the pressure on the cylinder and stop the leak temporarily.
    If you let it continue to leak, eventually the Fullers reservoir will empty and, with no friction fluid left, your brakes won't work.
  • DeadmanDeadman Frets: 3927
    I don't know what you're playing at by trying to be funny. The bloke has asked for genuine help.
    You know full well that water under a vehicle is a classic symptom of a worn window wiper mechanism.
    Get your own funny ship, this one is full.
    Fuck you  ;)
  • EricTheWearyEricTheWeary Frets: 16301
    My mate's Lotus was getting drips of water from the engine area and he got the AA out thinking it was the radiator. Turned out to be the water reservoir for the window washers hadn't been closed properly when he refilled it.
  • digitalscreamdigitalscream Frets: 26757
    If it's a BMW or Audi, it's probably just an indicator fluid leak. Common problem, most people just ignore it.
    <space for hire>
  • octatonicoctatonic Frets: 33847
    Says the boy racer man who has had his license for 5 minutes. :)
    Ah, but I've been a passenger watching asshole drivers for many years.
    Oh, and my licence actually turned up two days ago, thankyouverymuch. I'm a real boy now! :D
    <space for hire>
    LOL.
  • GagarynGagaryn Frets: 1553
    Condenser condensing.
  • kaypeejaykaypeejay Frets: 777
    Yep, and the radiators are always gonna radiate!
