Usually quite knowledgable with cars, but none of the previous motors I've used have had working air con..
Current one does, but today after 30 mins of driving with the air con on full whack, I stopped to fill the tyres up with air and noticed a puddle and water running from underneath the car. Couldnt quite make out where it was coming from, but it was dripping from somewhere on the underside of the car, a bit behind the engine bay.
It seemed clear, not luminous green like the previous car pissed out after a failed air con refill.
Is that normal? Just condensation?
Feedback
My truck did that too.
Totally normal.
The water drip would just be the moisture taken from the air as the A/C was running, and nothing to worry about.
If it was petrol/diesel then worry.
Cheers all.
If you let it continue to leak, eventually the Fullers reservoir will empty and, with no friction fluid left, your brakes won't work.
Offset "(Emp) - a little heavy on the hyperbole."
You know full well that water under a vehicle is a classic symptom of a worn window wiper mechanism.
Oh, and my licence actually turned up two days ago, thankyouverymuch. I'm a real boy now!
