What are some "stupid guitar rules" you believe in?
  • professorbenprofessorben Frets: 5105
    guitar solos on strats should be played with your head leaning forward over the guitar. on a les paul your head should be thrown back leaning away from it.
    Sg's. ?
  • digitalscreamdigitalscream Frets: 26671
    thebreeze said:
    You should learn the fretboard - I don't believe in this one but can't let it go.
    I helped make The Fretboard, therefore I'm exempt.
    <space for hire>
  • jaygtrjaygtr Frets: 218
    edited July 2017
    It's important to have arbitrary weight limits for your guitars. Say 8lb for a strat/tele and 9lb 8oz for a les Paul.
    Because when  you find the best sounding, best playing les Paul of your life that weighs 9lb 10oz you can pass it by! ;)
  • LebarqueLebarque Frets: 3888
    Sg's. ?
    Bin
  • TTBZTTBZ Frets: 2910
    Gibson into Marshall is the best tone, this is fact. Tele into marshall is ok though.
    edited July 2017
    Sadly it doesn't stay in tune now, needs a refret, has some significant warping, and the truss rod is knackered
  • dindudedindude Frets: 8539
    TTBZ said:
    Gibson into Marshall is the best tone if trying to still live in the 1970's, this is fact.
    Fixed it for you ;)
  • ReverendReverend Frets: 5006
    EMG pickups are for metal.
    I generally work on the rule that you should avoid any metal band that uses emg
    dindude said:
    Fixed it for you ;)
    Plenty of young bands use Marshall amps.
  • RockerRocker Frets: 4987
    TTBZ said
    dindude said:
    Fixed it for you ;)
    That is because they are plentiful at the Free cycle depots...
    Nil Satis Nisi Optimum
  • mbembe Frets: 1840
    When your strings sound dead there's no need to buy a new set. Just put the old ones in a pan of water and boil them for 15 minutes.
    I actually knew people who did this, but it was a very long time ago.
  • richardhomerrichardhomer Frets: 24839
    Getting a pan big enough to get my Strat in has always prevented me from trying this....
  • RavenousRavenous Frets: 1484
    That's why I play mandolin exclusively these days...
  • BigMonkaBigMonka Frets: 1782
    I've heated bass strings in vinegar before and they came out like brand new - helpful when you're skint and bass strings are expensive.
    Sound even tastier when fried in a little extra virgin olive oil.
    Fry them in butter to get your guitar playing accordingly.
    Learn to mime and use backing tracks. Make sure your amp is switched on :)
  • AlnicoAlnico Frets: 4616
    Is THAT what that means?
    Enlightened !!!
  • John_AJohn_A Frets: 3775
    I actually did this a few times many years ago and it does work, the strings do come out sounding a lot brighter for the brief time before they snap.  Probably more as a result of removing and replacing than the actual boiling.  Had good success with bass strings though!
  • LestratcasterLestratcaster Frets: 1093
    I've heard rubbing alcohol is good to clean them, and from somewhere Windex works?!
