Instagram
Just because you're paranoid, don't mean they're not after youits not even foolproof - SG's just want to dive sometimes. The other obvious suggestion is to remove the G-force and replace with something lightweight. Still no guarantees then, but doing that and adding a bigsby should do it
There isn't an ideal position for a strap button on an SG that stops neck dive. I like it on the top horn as it stops the guitar tipping forward as much. It needs to be closer to the 12th fret to stop neck dive
Instagram
What about a few fishing weights on the strings between the bridge and the tail piece.
Cheers
Just because you're paranoid, don't mean they're not after youMy Trading Feedback | You Bring The Band
Just because you're paranoid, don't mean they're not after youPut some coins in a bag and then tape the bag to the butt end of your guitar strap.
If it feels much better - and the extra weight is OK - that probably points you to the obvious solution. Have a dedicated strap for your SG and get someone clever (probably a woman) to sew the coins into the strap.
I like the traditional front strap position on an SG. I think the "swivel" on the strap button is part of the stage feel of an SG. I would imagine that your guitar will currently be neck heavy with the button in either position.
I think the problem is worth solving. Even if only 1% of the effort produced by your fretting hand is being used to support the neck.....that is still too much effort.
Someone I knew years ago did that, it worked perfectly. If I remember right it was a big ornate cowboy thing that said 'Calgary' on it, so presumably from the rodeo!
Seems the easiest solution to me, makes sense, though I couldn't go the cowboy decoration route myself
http://thefretboard.co.uk/discussion/109472/ngd-x2-something-fun-and-twangy-and-something-loud#latest
Should have gone to specsavers...
Just because you're paranoid, don't mean they're not after youNice buys dude, that tele deluxe...that's rather cool and have wondered about the mini humbucker sg's myself. Enjoy!
