I love the tone and sound of my LP. But i've been playing an HSS strat a lot and learning to play proper music - so scale practice, legato and arpeggio practice and the strat is soo much easier to play.
what would be marvellous would be an HSH or maybe HH guitar, with a trem. 22 frets, good access to the dusty end with the playability of this neck -
http://www.mightymite.com/mm2925----p-77.html (as i've got a highly polished and finished one on my strat and it's wonderful) but with the creamy and flutey sounds of my lester
what do you recon. it's the neck that makes the strat play so well.
it it impossible - and therefore I should just get a donor strat, swap the pups to hsh and buy another neck and shuddap. or do we suggest one of the PRS or are there other guitars out there?
budget - it depends. if I sold a few bits i'd have £500 immediately. If i had a mad moment I could flog the yamaha sa2200 which would release another £1K ish but then i'd regret selling the yam one day!
thoughts? options? remember it's all in the neck but with the LP sounds and good top access
ta
Do you have a preference for scale length? (I'm assuming your strat is typical 25.5 inch, i.e. longer than the Les Paul.)
I ask because many people here will probably have suggestions for both cases.
Custom 22 or DGT would be worth a look, but they might not have the same neck profile. I think the DGT is a better guitar, and I prefer the neck on it as well, but if you did want something shallower you would be able to get a wide-thin neck (or whatever they call it these days) as an additional option on the Custom 22.
Edit: Just realised that a full fat US Core line PRS would break the budget in the original post. The S2 series are really good guitars so that might be a better option. I actually prefer some of the S2 guitars to a lot of more expensive PRS guitars.
In my opinion, a Stratocaster-type electric guitar will not deliver the exact sounds of a Gibson LP and vice versa.
If money is a problem, you could probably get more sonic variety from your existing guitars by modifying their control wiring.
I advise against selling the Yamaha SA2200.
Thin, light, sounds great. The standard two pickup version can be had used for £300. Cheap as chips (if you can find one).
Avoid the bolt neck three pickup version, as it's a budget variant, and sucks ass.
Just because you're paranoid, don't mean they're not after youThis? The Korina body, maple cap would add a little Gibson to the SuperStrat formula.
https://www.guitar.co.uk/reverend-gil-parris-signature-coffee-burst-flame-maple
the good things about the strat - neck profile (ie full fat C shape) plus the better access to the toppier frets - albeit admittedly not as good as the prs. plus i like a trem. in fact it's THAT neck - i've tried modern C and they are too thin. the gibbo neck is confortable and good for blues widdling but not as fast or as smooth as the strat.
I guess it's the scale length as much as anything else that makes the strat sound spankier than the lester. I agree about the Yamaha - it'll be the brian may to go first plus a few pedals
Depends on budget - as above - Ibanez RG is a great bet (like the one I'm selling
More money, one word - Feline.
I have a Feline Panther with the most amazing, easy to use pickup switching - I can get really close to strat, SG and widdlefest very easily
