First driving lesson...
In an hour and 20 minutes... if I die, you can have my amps.
    Pm'd
    Nobody is guaranteed tomorrow.....
  • You'll be fine. Just remember, if you hit anything, simply kill the instructor, and no-one will ever know :)
  • So you are on the roads now?
    I'm off to the safe space under the stairs.
    Good tip!
  • MyrandaMyranda Frets: 2940
    Good tip!
    Unless there are others involved - if you hit another car etc. - then you have to kill them too... and any passers by
  • Good luck
    Break a leg!
  • Hertz32Hertz32 Frets: 2248
    Remember that a car is really just a big Wheely death machine and drive cautiously.
    and if you stall, we get a good giggle out of it.
    'Awibble'
  • replace the pedal board straight away, its only got 3 pedals only one of which is a "drive"
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Remember, you're operating a deadly machine, you'll absolutely love it.
  • ICBMICBM Frets: 72767
    You'll find there's a bit of a lag when you press the left footswitch, you need to time it so the change is as you take your foot off not when you press it down. Slightly tricky to get the hang of, but you'll get used to it.
    The two right-hand pedals don't really work together very well either - it's one or the other really.
    Don't try stacking the pedals.
    Didn't stall. So in yer face @Hertz32 !! ;)
    Also only half dead.
  • neilgneilg Frets: 94
    Myranda said:
    Good tip!
    What if there's CCTV, he'll have to go find the files and delete them too.
  • You learning to drive in North London (I believe that's where you were when I collected the M13 from you)?  If so, then best of British luck to you, wouldn't want to be a learner round there!
    edited September 2017
    Liar.  ;)
    'Awibble'
    Liar.  ;)
    Nope!
  • monquixotemonquixote Frets: 17706
    The inside half?
    The inside half?
    It needs microwaving.
    Liar.  ;)
    He's learning on an automatic cos he's a FAGGOT.
