essential fx in a pedal board
BarneyBarney Frets: 619
whats every bodies favorite or essential fx that should be included in a a setup for guitar..?
  • d8md8m Frets: 2434
    It's largely down to personal preference and playing style.
    So everyone's rig will be different to an extent.
    For me personally I could get by with a decent distortion and a delay(assuming I can drive the amp naturally).
  • 1) Tuner
    OK I'm done.
    eight wahs in a row.
  • RolandRoland Frets: 8816
    Tuner,
    TubeScreamer of some sort,
    Wah,
    Chorus if you're into that sort of thing,
    and after that it's personal choice. I like to leave a space for a pint glass and some talcum powder.
  • BucketBucket Frets: 7751
    edited February 2014
    You are Kirk and ICM £5.
    For me, a delay is pretty important, and I like fuzz as well. If I'm using single-coils I will want a compressor too.
    My current small board is about as minimal as I want to go atm:
    Wah - (tuner yet to be purchased) - compressor - fuzz - OD - trem - delay - reverb
  • BidleyBidley Frets: 2947
    Delay and some sort of lead boost, IMO.
  • mike_lmike_l Frets: 5700
    Tuner
    wah (Weeping Demon)
    Boost (ATM Bad Monkey or SD-1)
    Phaser (Phase 90) or Flanger (Micro flanger)
    Delay
     As a minimal board.
  • vizviz Frets: 10760
    Wah & Overdrive in the front;
    Analogue Delay & Chorus in the loop.
  • dindudedindude Frets: 8561
    Tuner-drive-delay I could get by with. Over and above this it would be more drive flavours and trem/phase for mods.
  • Old originals band: Tuner, Rat, Delay would've done it at a push.
    Old covers band: Tuner, Rat, Chorus would've probably just about worked but been a bit shit.
  • Tuner, Boost, Drive, Vibe, Delay. (Drive can be 1 to 3 pedals at least!, Vibe is the king of all modulation)
  • mike_l said:
    Tuner
    wah (Weeping Demon)
    Delay
     As a minimal board.
    That's basically my gigging board right there, albeit with a clean boost (Carl Martin Hydra) instead of the BM/SD-1 :)
    However, tuner aside...my amp takes care of all the distortion, and I'd quite happily gig with just a delay pedal if I had to.
    <space for hire>
  • tube screamer and I'm happy,
    tube screamer and blues breaker/morning glory (either) and I'm VERY happy.
    anything else is icing on the cake.
    But yeah, in seriousness...
    I need wah, phaser, dual delay (one set to regular digital mode, and the other set to reverse mode) and reverb. I don't really need anything else, but I do use a volume pedal as well, as it is more convinient than using the knob on the guitar.
  • ESBlondeESBlonde Frets: 3597
    Just stripped my big board to build a simple ready to go affair.
    Overdrive, chorus, delay. ( + tuner). Enough to get by for most work I do, I have more stuff but they will come out for special occasions as applicable.
  • 57Deluxe57Deluxe Frets: 7350
    Delay and a Transparent Drive - you can always dig-in hard on your picking to get some extra aggressive tone - and shout and jump up and down more to convey mayhem...
    <Vintage BOSS Upgrades>
  • If I play a strat style guitar where I can access the volume pot I can get away with just tuner and delay.
    My current setup is: tuner -> gate -> boost -> volume pedal -> (amp) -> delay
    I get my modulation from the delay (DD20).  I don't like an entirely wet signal when it comes to modulation but modulated delays sound good to me.
  • I suppose the basic categories are Tuner; EQ (inc Wah); Drive ( boost and/or fuzz/ distortion); Modulation ( inc Tremolo); Time ( reverb/ delay).
    So, one from each of those would be relatively versatile ( in a ball park kind of way). So, my board is tuner, OD, clean boost, tremolo, delay ( although its a big one with 3 delays). So I should learn to live without the clean boost and get a wah or auto wah on there and I would be ready for anything!
  • Dave_McDave_Mc Frets: 2388
    +1
    Well, I go for pedals in that vein rather than those exact ones- I probably prefer an SD1 to a TS but it's similar and I prefer my dano timmy clone to my bluesbreaker clone, but they're both in the same ballpark- something ts-like and something more transparent.
    Well and a tuner too, obviously.
    That's not to say that given the option I might not like some other pedals etc., but I could get by with those 3 (assuming I'm allowed to pick the amp myself).
    if i had to be brutal, i would need:
    compressor (analogman bi-comp)
    tuner (anything)
    fuzz (Black Arts Pharaoh)
    ...all into a big clean amp...I don't solo, so can get away without any modulation or time pedals...and my clean passages can be dry without impacting the mood of the songs.
