OK I'm done.
Tuner
wah (Weeping Demon)
Boost (ATM Bad Monkey or SD-1)
Phaser (Phase 90) or Flanger (Micro flanger)
Delay
As a minimal board.
Analogue Delay & Chorus in the loop.
tube screamer and blues breaker/morning glory (either) and I'm VERY happy.
anything else is icing on the cake.
I need wah, phaser, dual delay (one set to regular digital mode, and the other set to reverse mode) and reverb. I don't really need anything else, but I do use a volume pedal as well, as it is more convinient than using the knob on the guitar.
Overdrive, chorus, delay. ( + tuner). Enough to get by for most work I do, I have more stuff but they will come out for special occasions as applicable.
So, one from each of those would be relatively versatile ( in a ball park kind of way). So, my board is tuner, OD, clean boost, tremolo, delay ( although its a big one with 3 delays). So I should learn to live without the clean boost and get a wah or auto wah on there and I would be ready for anything!
Well, I go for pedals in that vein rather than those exact ones- I probably prefer an SD1 to a TS but it's similar and I prefer my dano timmy clone to my bluesbreaker clone, but they're both in the same ballpark- something ts-like and something more transparent.
Well and a tuner too, obviously.
That's not to say that given the option I might not like some other pedals etc., but I could get by with those 3 (assuming I'm allowed to pick the amp myself).
compressor (analogman bi-comp)
tuner (anything)
fuzz (Black Arts Pharaoh)
...all into a big clean amp...I don't solo, so can get away without any modulation or time pedals...and my clean passages can be dry without impacting the mood of the songs.
