PJ Bass - Control Layout - now accidentally turned into a build thread!
12346»
  • FunkfingersFunkfingers Frets: 14599
    Alright. You can all point and laugh.
    Short, wireless keyboard. Yah, boo, sucks. ;)
    Have you had a go yet? How are you finding the pickups?
    Very brief - just mostly tuning, setting intonation and pickup height. I'll have a go later, and really I should wait till I have some knobs on it ;)
    First impression tho - they are high output..! P is solid thumpy P, more modern voice than vintage - J is pretty well balanced with it.
    I think I will like...
    Ok that’s good, I was worried the J wouldn’t keep up, I’ve not tried the J but the P is properly loud compared to a vintage style pickup.
    I do think they look really cool with the Allen pole pieces
    The J is pretty pokey.. it's raised up a bit compared to the P, but it balances pretty well!
    TTony said:
    Looking good Mr B.
    Are you sure about that colour scheme though?
    :D
    Don't you start ;)
    I only have small fingers ;)
    Oh, one little addition about the J - it's a split coil - and it really is very quiet hum and noise wise..
    CUE: RandallFlagg with a single entendre. ;)
    He doesn't venture into Bass - makes him come out in hives ;)
    Knobs arrived. Knobs fitted. This one is done.
  • TTonyTTony Frets: 27729
    Looks good enough to, errrr, play.
    My body/neck have just arrived (yesterday).  I'm going to try some colour staining options on mine, so it'll take a little while to get it all together.
    Who did you use for the pots & knobs?
    Allparts - availability was sketchy at best... tone on one is a bit notchy so I might swap it out for another one..
  • ICBMICBM Frets: 72734
    Try Servisol first.
    If that fails try WD-40…
    Less hassle than changing the pot, if it works.
    ICBM said:
    Try Servisol first.
    I actually think the pot itself is a bit fooked - I can't be arsed to send it back so I may just get another.
    It works fine at the mo, but might fail in the future tho.
    Did it work correctly before you fitted the control knobs?
    Some times, a poorly aligned control knob can foul against the pickguard, pushing the innards of the pot apart by enough to cause crackling or interrupt the signal.
    Nope. Was dodgy when I took it out the packet. Decided to fit it (impatience) and then replace later once I've ordered one
