Ebay fun - returns!!!!
  • I feel like I'm banging my head against a brick wall here - as anyone who buys these or any other bkp could go to the website, compare output and ask for a return if it's different?
  • WezVWezV Frets: 16741
    But if you can say “I checked with BKP, and here is the email confirming they are okay” then you have done as much as you can.
    If in doubt sell them as a custom mule and state the DC resistance.  I have sold a few non- standard BKP’s in my time and they always sell just fine.
  • I'm definitely in the camp of "plug it in and see if it sounds good"
    If I bought a high end sound system, I'd not be getting out a ruler to check that the speakers are exactly to the mm what they were advertised as, or taking wood samples to check the purity of the wood. I'd be plugging it in and belting a bit of Wagner's Ring Cycle through it, whilst dreaming happy thoughts of a Valkyrie giving up her immortality to spend the rest of her days doing unspeakably naughty things to me with her costume on.
  • Thanks @wezv
    This thread is like when you walk in on a conversation, realise what's happening and quickly turn round and walk off with one of those "that's awkward!" looks on your face ;)
  • Lol.
    I've learned loads about pickups in this thread.
    edited November 2017
    Thanks @wezv
    FWIW I am one of the buggers that always asked for things like “can I have a mule, but can you......”
    i moved away from BKP when customisation  was no longer an option
  • (That might be just about the most middle class fantasy one could have)
    I don’t buy off the rack darling
  • Just for reference I have a mule neck here that I bought last July and I wrote the details on it with a sharpie (cos bkp cannot it would seem) the resistance I noted was 7.08k at probably 20+ degrees, it measured 6.92k tonight at about 15 degrees. Same meter.
  • adamm82adamm82 Frets: 448
    So I listed a set of pickups (old swap out and swap in hob, not sat in a drawer for years) on ebay, sold them within 20 mins.
    Totally immaculate.
    Sent special delivery, at an extra cost to myself.
    Got an email today saying item not as described, return expected.
    I copied the detail from the manufacturer'  site into my listing and I'm being told the output differs from the manufacturer, with one pup 0.1k under and the other 0.7k under.
    (7.7 V 8.4).
    Obv nothing you can do with ebay - please return for a full refund and I'll take the hit on  postage and then relist.
    This is why I always only do face to face and should never have used ebay - arghhh!!!!
    You must have encountered a OCD tone chaser type. Or a .....
  • Philly_QPhilly_Q Frets: 23012
    Or you could just say they're Bare Knuckle Mules* and not say anything about the specs.  You're not misleading anyone, not everyone has a multimeter to check specs and there's no earthly reason why you should be expected to have one either.
    You've ended up in a weird position of buying something in good faith, selling it in good faith, inadvertently finding out it's not quite standard specification.... and somehow feeling that's your fault.
    (*Although as Feline has pointed out, you can't actually prove they're Mules because BKP steadfastly refuse to label their pickups!)
    WezV said:
    Thanks @wezv
    Ah, remember the days when they started refusing to make A5 Mules....
  • Interesting that Amarok1971 has mules that are twenty percent out on manufacturer spec - and change ten percent based on temperature!
    I was more pissed that someone had stripped one of the threads and not told me!
    Philly_Q said:
    WezV said:
    Thanks @wezv
    In fairness, the range grew to the point where there was something for everyone so all the custom winds and magnet choices for each model were not really needed.
    but I enjoyed those conversations with Tim pinning down exactly why I might want my mule over or underwound
    Proof that DC resistance is a silly measurement.
  • amarok1971amarok1971 Frets: 338
    Resistance definitely is futile  B
    18reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • And just to finish the thread off....
    What do you call a detective electrician?
    Sherlock Ohms
    6reaction image LOL 1reaction image Wow! 0reaction image Wisdom
  • FelineGuitarsFelineGuitars Frets: 11619
    WezV said:
    So @Felineguitars what you're saying is potentially get three sets of The Mule pickups and all three could be different outputs?
    That is a given
    No - they will all pretty much correspond in terms of winding count, which is what will determine the output strength.
    And much care will be taken to make a consistent product, but there is a manufacturing tolerance in all things
    I can actually see that a buyer of secondhand BKPs would have to take a meter to the pickups to see which is bridge and which is neck if the little labels on the leads have come off.
    But seriously the answer is to solder the things in and TRY them
    The buyer may actually like these ones MORE than the other ones
    Also remember the whole thing about Gibson PAFs is the amount of variation (which would make these ones closely matched) and that some players will like one more and another player may like a different one.
    BKP simply decided on a spec and have stuck with it for the most part, but some players may like one either wound  slightly less or slightly more.
