Who really likes the Tubescreamer?
  • Ro_SRo_S Frets: 929
    best suited to single coil pickups and into a Fender voiced amp, but not into an amp set clean.
    over 20 effects pedals FOR SALE, click here to see my classifieds thread.   My trading feedback
    Effects for Me & my Monkey
    YouTube channel     Facebook         Fretboard's "resident pedal supremo" - mgaw
    darcym said:
    everyone always says they are basically the same thing, yet the SD-1 sounds totally different to an 808/TS-9/TS-10 when I've compared, even tried the Keeley modded one, it was a fine pedal on it's own but it just didn't work or sound like a tubescreamer when I tried them
    They're voiced eq wise the same, but the asymmetrical clipping of the SD1 adds a gritty edge to it.
  • Yeah, I got a Tubescreamer Mini earlier this year and love it.  I use it to tighten up any distortion pedals I use, mainly I use it as a boost.
    For me, there are only 2 overdrive pedals and one of them isn't a tubescreamer.
    I remember years ago trying a TS and a big-box Rat in a shop. I ended up walking out with the Rat.
  • A tubescreamer sounds a bit softer to me than an SD1. It seems to make for a nicer sound with cleaner amps and single coils. With higher gain and using as a boost I usually prefer the harder edge the SD1 has, but theres probably merit in owning both, especially as the SD1 is so cheap
  • Danny1969Danny1969 Frets: 10490
    Strat into TS into a clean Fender amp is a sound I like a lot, obviously great into a dirty amp as well. A bit overpriced now though for what it is, hence the cheaper clones everywhere
  • I've just looked at some ebay sold listings. Used TS-9s go for around £70, used SD-1s for half that, £35. The Tube Screamer name is obviously worth a lot! You get an extra diode with the boss as well.
    This is magnified with older pedals, old TS-808s go for far sillier money than OD-1s.
  • randellarandella Frets: 4336
    edited November 2017
    darcym said:
    randella said:
    I'm not sure there's a big enough difference from my SD-1 to bother splashing for a TS, but as a concept (middly boost into already overdriven amp) I love it.
    @darcym - fair do's, I will freely admit I've never used a TS of any description. I was scratching around for suggestions of bits that Mrs. R. could get me for Christmas years back and I needed a replacement for my fried drive.
    I remembered a friend from school had an SD-1, this was a long time ago. It was his dad's, but we used to use it to kick our amps up a bit, so I went with the Boss as I remembered it working well. £39 from Anderton's, done.
    I've made my sound around it now, so not convinced I'm missing anything that I could magically get from a TS, if you see what I mean. I could have been a bit clearer in the first post.
    Speaking of that fried pedal, it was a Joe Satriani Vox Ice 9 that I got for buttons in a GAK sale on a whim. It was a great pedal, a bit smoother than the Boss so I guess a bit more like a TS and it had a great mid hump. And a second boost too.
    I've tuned everything around the SD-1 now and love it, but I do miss that Vox.
    The overpriced bit really applies to that name "Tube Screamer" which of course is an Ibanez trade mark. But fortunately you can buy many a good 'tube screamer' for SD-1 kind of prices just by other brands under other names. There are tons of decent TS clones out there that sound as good as a TS-9 (or an 808 etc). Digitech CM-2/Bad Monkey, Moorer Green Mile, Joyo Vintage Overdrive etc etc all make doe a very decent sounding clone....the Digitech Hardwire Overdrive I'd say is BETTER as it has extra features added. Another notable mention is the Visual Sound Route 808 has a handy bass boost option for those that dislike the TS's inherent bass cut. I had the Double Trouble pedal for a while - that was great (2 TS's in one pedal).
    Basic point being - if one isn't fussed about the actual name/look sitting on their board they can have that sound for cheapo money....via another brands clone.
  • darcymdarcym Frets: 1297
    no no you're right, everyone says the SD-1 is a tubescreamer, but for me, I just don't get it at all, they sound nothing alike, no matter how many people tell me they are basically the same circuit or voicing.
    I like the SD-1, but I like it because it doesn't sound like the tubescramers I love.
  • ICBMICBM Frets: 72786
    The SD-1 and the Tube Screamer *are* basically the same circuit, but the small differences add up to quite a different sound, if that makes sense.
    It's a bit like the Fender Bassman and the Marshall JTM45, which are even closer in circuit terms but sound quite different.
    It's not just big non-MV amps the TS sounds great with either - they work extremely well into a Mesa Dual Rectifier at any volume, for the same reason - they tighten up a loose, scooped sound and produce a singing lead tone that the amp won't do by itself.
    I prefer the TS with Mesas and the SD-1 with Marshalls.
  • 57Deluxe57Deluxe Frets: 7348
    Yes - any TS dynamic and I'm happy.
    <Vintage BOSS Upgrades>
  • builttospillbuilttospill Frets: 461
    Had a late 70's TS-808, now have and OD-1 and the OD-1 won.
  • I've got the TS9 which I acquired back in 2008 I think, I mainly used it to boost for solos over an already overdriven amp, and it worked well.
    Now I use it to add extra bite and tighten up my 6505+'s flubbiness sometimes, by dialling in lower gain on the amp, setting drive to zero and level to around 3/4's of the way up. You get a mid-hump and more punch which is great and I like it. Usually flit between that and a Maxon OD808, I find the TS9 is creamier and ballsier, the OD808 is tighter sounding low end wise.
    In a nutshell, this is basically why 9 out of every 10 boutique OD pedals is more or less a Tubescreamer, isn't it?
    Yes. It's a basically good circuit, and the sound can be tweaked quite a lot by changing component values, or sometimes adding slightly different elements, like a Rat tone stage.
    And the other 1 out of 10 is more or less an Electra Distortion :).
    That reminds me. I need to dig out the stripboard Lovepedal COT50 I made that doesn't distort and work out how the hell I managed to screw up something so simple.
    I digress. Back to Tubescreamers.
    Didin't connect the clipping diodes at one end? Then it's just a single-transistor booster.
    To also digress, it absolutely amazes me the hype there is around this company and these pedals, and the various other stupidly-named variations they do - they seem to be rated for "just adding more " and "sounding great into a cooking valve amp"… well of course they do, the clue is in the cooking valve amp bit! And that they're not really adding much at all - one transistor and some diode clipping.
    Emperor's new clothes in a marketing package. At least the Tube Screamer circuit is a bit more sophisticated.
  • jpfampsjpfamps Frets: 2734
    Tubescreamers work well will a BF Fender-style amp and a Fender guitar.
    Fender BF-style amps have a pronounced mid-cut and this is complemented by a mid boost of the Tubescreamer.
    However, I can't imagine a Tubescreamer workng well with say a Les Paul and an AC30.
