Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
I remember years ago trying a TS and a big-box Rat in a shop. I ended up walking out with the Rat.
This is magnified with older pedals, old TS-808s go for far sillier money than OD-1s.
I remembered a friend from school had an SD-1, this was a long time ago. It was his dad's, but we used to use it to kick our amps up a bit, so I went with the Boss as I remembered it working well. £39 from Anderton's, done.
I've made my sound around it now, so not convinced I'm missing anything that I could magically get from a TS, if you see what I mean. I could have been a bit clearer in the first post.
I've tuned everything around the SD-1 now and love it, but I do miss that Vox.
The overpriced bit really applies to that name "Tube Screamer" which of course is an Ibanez trade mark. But fortunately you can buy many a good 'tube screamer' for SD-1 kind of prices just by other brands under other names. There are tons of decent TS clones out there that sound as good as a TS-9 (or an 808 etc). Digitech CM-2/Bad Monkey, Moorer Green Mile, Joyo Vintage Overdrive etc etc all make doe a very decent sounding clone....the Digitech Hardwire Overdrive I'd say is BETTER as it has extra features added. Another notable mention is the Visual Sound Route 808 has a handy bass boost option for those that dislike the TS's inherent bass cut. I had the Double Trouble pedal for a while - that was great (2 TS's in one pedal).
Basic point being - if one isn't fussed about the actual name/look sitting on their board they can have that sound for cheapo money....via another brands clone.
no no you're right, everyone says the SD-1 is a tubescreamer, but for me, I just don't get it at all, they sound nothing alike, no matter how many people tell me they are basically the same circuit or voicing.
I like the SD-1, but I like it because it doesn't sound like the tubescramers I love.
It's a bit like the Fender Bassman and the Marshall JTM45, which are even closer in circuit terms but sound quite different.
It's not just big non-MV amps the TS sounds great with either - they work extremely well into a Mesa Dual Rectifier at any volume, for the same reason - they tighten up a loose, scooped sound and produce a singing lead tone that the amp won't do by itself.
I prefer the TS with Mesas and the SD-1 with Marshalls.
Now I use it to add extra bite and tighten up my 6505+'s flubbiness sometimes, by dialling in lower gain on the amp, setting drive to zero and level to around 3/4's of the way up. You get a mid-hump and more punch which is great and I like it. Usually flit between that and a Maxon OD808, I find the TS9 is creamier and ballsier, the OD808 is tighter sounding low end wise.
And the other 1 out of 10 is more or less an Electra Distortion .
I digress. Back to Tubescreamers.
To also digress, it absolutely amazes me the hype there is around this company and these pedals, and the various other stupidly-named variations they do - they seem to be rated for "just adding more " and "sounding great into a cooking valve amp"… well of course they do, the clue is in the cooking valve amp bit! And that they're not really adding much at all - one transistor and some diode clipping.
Emperor's new clothes in a marketing package. At least the Tube Screamer circuit is a bit more sophisticated.
Tubescreamers work well will a BF Fender-style amp and a Fender guitar.
Fender BF-style amps have a pronounced mid-cut and this is complemented by a mid boost of the Tubescreamer.
However, I can't imagine a Tubescreamer workng well with say a Les Paul and an AC30.
