The story of a guitar...
So, yesterday, I decided to go for a walk around the back of the village I live, little rural roads, secluded and quiet. Quite common for me on a day off. Cold, bracing, lovely. Already buzzing from a nice time with my girlfriend.
Car drove past, ah, it's my dad's old mate Joe. Big wave, he pulled up. Talked guitars. I borrowed his '74 SG in 1992 for my first proper gig, the 25th anniversary of which just passed within the last fortnight (I still have it on VHS!).
Last time I saw the guitar, it was on the concrete floor of an outhouse, headstock snapped off. I berated him and told him it was criminal. He's since had it repaired but still when I went round to his to have a look, it was very dirty, loosely strung, no bridge, pots knackered. Again, I had to let him know that this just wasn't good enough!
I asked him how much he would want if he chose to sell it. As he knows my history with the guitar and how much I loved it, he has remarkably decided that if I were to be the owner it would make him very happy to know it has gone to a good home. So it's now mine to hopefully restore to as close as possible to its former glory.
Very pleased - and a great day got better!
Main picture is post initial clean up, the rest when I got it home.
I understand he has the original harmonica bridge, which I need to collect. He did show me but I didn't realise it was the correct one (he himself thought he'd nicked the original for his L6). The pick-ups are DiMarzios, I believe, most likely Super Distortions, although they're unmarked on the back.
Few questions:
Gibsons and Fenders look better the more they look like they've been left on the floor of an outhouse. This is why I don't like PRS guitars - a Custom 22 after a similar ordeal would just look a mess, and not in a good way
Enjoy
Something a bit different to the Custom 24.
The little leaf things are pointers and can be got from here http://www.axesrus.co.uk/Control-Pointers-p/alphapointers.htm
@ICBM Can you advise on my hardware questions?
My band, Red For Dissent
Keen to see how it progresses!
Pics of the baseplates will say a lot
Instagram
Instagram
I have had good results removing filler from breaks. its a bit like excavation, but well worth doing. You may as well get some strings on and play it for a bit first
Instagram
1. Will the neck/headstock hold tension?
2. Can I locate parts to complete the Harmonica Bridge. Classifieds?
And possibly not in that order.
With my skill level I would probably want a guitar tech to look at the repair even before stringing up.
If you just need the pins https://www.ebay.co.uk/itm/Kluson-Harmonica-Bridge-Studs-Brass-Set-Of-Two/252727168839
If it were me I'd make a new loom using CTS short shaft pots, keep the switch if OK.
If you're not comfortable soldering get a harness from Ash or one of our other wonderful contributing forum businesses.
As for checking the repair, I'd say string it up and see what occurs personally. There's only one way to find out if it will take the tension.
You need to use the harmonica bridge - the post holes are directly at right angles to the strings and anything else without the offset to the bass side won't intonate properly.
For pots I would use 500K Log CTS.
It also looks like it could do with a proper fret dress and re-crown - there's significant wear in the lower positions, and it looks like it's been badly dressed already, leaving the fret tops flat... if so it won't intonate properly or sound good since every fret will sound like a miniature sitar. It might just be a trick of the photos though.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
