Nearest cutter I had wasn't quite big enough. Best bit of hardwood I had was quite thick.. so...
Told you it was comedy. However, a rasp and liberal use of sander meant it was close..
And out came good old wood filler esq.
Stop sniggering at the back there!!
You just need a few coats of some really thick paint over it and no-one will ever know.
Tho you will all know and it's bound to annoy you
You guys are labouring under the delusion that this is anything more than a quick hatchet job!
if it happens it will be a slight line that follows the knobs quite closely - hardly worth worrying about.
Wood shrinks more along the grain than across it, but the ratio of dimensional shrinkages is different for each wood.
If plugging with the same type of wood it makes sense to match the grain direction and there is a good chance you will never see the fill, no guarantees though.
If plugging with a different wood it matters less as its likely to reappear as a bit of shrinkage whatever you do
Instagram
I'm going to Preamp it up so it will sound much better than it did..
Yeah. Sort of. Does it look any good? Not really. Do I care? Not much..
It will be a tight fit tho - needs 28mm clearance and the cavity is 29mm..
It'd work better if you installed all 3 of those.
That's a single loom
