I've done it before, and then still found tiny bits of black plastic a year later. The router throws them *everywhere*. Plus, it's harder to control accurately unless you've made a template first. For a one-off job like that, cutting by hand would be easier.
Instagram
Anyroadup, after some sleep today, a bit of paper and scissor action sees a scratchplate shape I think I am happy with, this is working from the perspective of modifying a Standard scratchplate and not making completely from, erm scratch.....I like the way the rear corner matches the curve of the front edge of the bridge plate and the way it extends slightly up the sides of the pickups looks better too, thanks to @WezV for the suggestion, sometimes you can't see the wood for the trees....
I have in the mail 2 scratchplates,one Black Pearl and one White Pearl....lets see how this goes!.....
http://i.imgur.com/EWdNUmD.jpg
http://i.imgur.com/ee3lvLX.jpg
All assembled, set up, intonated etc, it all needs to settle and next string change will see the intonation screws shortened........
Pretty happy with the result, I will probably replace the P90’s at some point, which are ok, I'll see how I get on with them...
Photos...
http://i.imgur.com/bmxWX1o.jpg
http://i.imgur.com/hEbFyRy.jpg
I'll do better photos tomorrow in daylight...
looks bangin!
Custom Swamp Ash Mustang body from Legit kits in the US. Sea Foam Green
Allparts Baseball bat neck modded to Vee profile, body colour headstock with custom decal and locking tuners 25.5" scale
Custom engraved neck plate
Fender Toronado bridge modified to top loader and Tele compensated saddles
Mustang control plate
CTS solid shaft volume pot with Jazz Bass Knob.
Modified Mustang scratchplate.
Iron Gear P90's
Schaller straplocks
I like the finish - looks good with the grain showing.
Nil Satis Nisi Optimum
But wait!
Theres more!
A guitar for the Eldest Grandson, probably a hardtail Strat with a Tele neck......
And a custom Mustang Short Scale (30") Bass in Roasted Swamp Ash, natiral finish with Maple Squier Bronco neck......
Watch this space slowcoaches!.....
Gotta love a mustang (or two or three
