Do you set intonation with guitar laying flat or in playing position ?
  • ICBMICBM Frets: 72687
    Even if there were a slight change in pitch, would that be enough to have a significant effect where the bridge saddles need to be?
    It's not the change in pitch, it's the change in relief and hence action height, which affects how much the string has to be 'bent' down to the frets and hence the pitch rise, and is what you're compensating for with the intonation adjustment.
    It may not be that significant but it is definitely measurable with a good tuner, so you may as well do it right.
  • ClarkyClarky Frets: 3261
    I've always done it in playing position but not thought about it be before.
    I have Floyd Rose bridges..
    if you tune the guitar in the playing position and then lay it flat you'll see the tuning move
    on a Floyd this means the bridge is moving and therefore so are the saddles
    I did some measurements of my own using the Ultra-tuner in Amplitube 4. I found it difficult to get very precise measurements, but there appear to be small measurable effects. It's a bit academic because I always set things up in playing position and, as you say, 'you may as well do it right' to remove any possible doubt.
    It's not a competition.
  • flying_pieflying_pie Frets: 1818
    One approach would be to consider that it's not relevant if the difference between methods is measurable on a tuner. It would only matter if the difference was at a perceivable threshold for human ears to detect it.
    Also it isn't important whether you SET the action in a playing or lying flat position that matters but which position you CHECK it in. I'd wager virtually all of us would do that in the playing position.
    How can you not set intonation in anything other than playing position?
    And why would you even want to?
    Because holding a guitar in your lap + screw drivers = BAD...
  • One approach would be to consider that it's not relevant if the difference between methods is measurable on a tuner. It would only matter if the difference was at a perceivable threshold for human ears to detect it.
    It's a fair point but it's about avoiding build up of errors for me. There are a whole bunch of things that affect the tuning of guitars while playing (temperature, drift with time..) that might lead to something that becomes discernible. I'd rather minimise possible sources of error, but maybe I'm a bit OCD about these things. Also, even though I might not hear it, someone else might :)
    This ^^^  the effects of gravity on a heavy bridge!
    www.maltingsaudio.co.uk
  • 57Deluxe57Deluxe Frets: 7345
    BOTH - -and when standing up with it...
    <Vintage BOSS Upgrades>
    Did you know, that if you put the arm on, and swivel it so that it's pointing forwards, it precisely counteracts the effect of gravity pulling the neck down, so that you can get perfect intonation with the guitar lying flat?
    Hopefully you wouldn't be adjusting intonation with a compressed air power-driver.
