Was looking at the vocals, but I'm not that I can sing some of them without going down an octave. Most of the easy ones seem to be taken.
I've never been able to do Vocal 2, DG's part and that does need an electro-acoustic strummed along to it to sound right.
I can bring my Gretsch which will get close enough for that if someone wants to play it?
Just because you're paranoid, don't mean they're not after youMy Trading Feedback | You Bring The Band
Just because you're paranoid, don't mean they're not after youSeems like the consensus is to do Beat It in E.
@crunchman
@darthed1981
@Brocco
@peteri
Come Together has two solo's (not yet claimed), the first of which is harmonised. Although this makes me feel a little uncomfortable, I would like to put my name down for one of the harmonised solo parts.
It's subtle through the verses and gets a bit more enthusiastic towards the end over the second solo.
Also we can't fade out as per studio track so I'll use the same contact point that DG does live to signal the ending.
Listen to any live version. DG hits the very top frets in the solo only once and it's right before the end. When you hear that it means finish next time around.....
I've got the BT if you want it and that it set up to finish as per the live track.
@lovestrat74 @Jonathangus
