I'd look into replacing the pots and switch too - its not expensive to do but makes a world of difference to the sound and feel of the guitar.
Cheap aftermarket parts are a lot better than they used to be!
Tuners looks like I can get an acceptable set for around £15.
Pots can be had for around £3 each from what a member has posted & 3 way switch around the same.
From the above it would seem that for around £60 I can transform the guitar.
OK tonally it is never going to compete with an expensive Gibson but I would imagine that it would be on a par with some of the Epi offerings whilst only owing me £85 ?
Also it is a cheap platform for me to learn on.
They must surely be better than what is in the guitar at present ?
I have decided that I am going to go ahead & swap out the tuners, pups & pots & see what improvements it makes.
First job is to remove that hardware & see what length pots & diameter tuners I need I think.
Pups are standard 50mm & 52 mm.
Yesterday the Epiphone HB pups, courtesy of Rocker, arrived plus a set of Vanson (stamped Wilkinson) E-Z-Lok tuners, 4 x 500k Alpha Log pots, 3 way toggle switch & 2 x 0.047 capacitors.
I also received a pair of Vanson 59 Alnico V PAF HB"s which I had ordered as I wasn"t sure that I was getting the Epiphone pups.
I spent the day installing all the new parts including making up a new wiring harness.
I fitted the Epiphone pups.
I am very pleased with the results.
The guitar now stays in tune, sounds much better & the tone pots now work as they should.
Now I have seen how easy it is to swap parts I think I will try the Vanson pups in it as well to see how they sound compared to the Epiphone pups.
Thanks for every ones advice & suggestions & special thanks to "Rocker" for the Epi pups..
Wow.
The Epi pups were a significant improvement on the pups the guitar came with but these Vanson pups are even better.
The guitar sounds great & I am very happy with the sound from these Vansons
The guitar owes me just under £100 now but to hear it you wouldn"t think it was a £25 guitar with £70 odd of upgrades.
I"m borrowing an Epi LP Custom this evening so will see what it sounds like compared to that.
