Les paul low end flub
  • brooombrooom Frets: 1175
    I like alnico III low wind pickups on les pauls to help with low end.
  • FelineGuitarsFelineGuitars Frets: 11629
    I have worked long and hard to get Les Pauls to sound tighter and more defined with less low end mush and a better/wider frequency range .
    Certain hardware choices, and Pickup choices etc can help
    Here are my top 3 LP tighteners:
    1) Fit an Earvana nut
    2)Try changing the tailpiece to lightweight aluminium
    3) Choose a pickup that has slightly less low end - a great example is BKP Riff Raff or Oil City Pat '63 (both still great PAF types - or Pat Number pickups to be more specific, but with a tighter less flubby bottom end)
    Just out of interest, may I ask if you would say the BKP Mule also has the right amount of low end or not so much compared to the Riff Raff?
  • daveyhdaveyh Frets: 684
    edited March 2018
    Id be definitely interested in the Riff Raff, I’be just discovered the Cobras for strat
    The Mule has a touch more low end to my ears than the riff raff - more windings and the A5 in the RR gives a more potent top end than the A4 in the mule.
    But do also do things to affect the acoustic (unplugged) tone too as it will translate when plugged in
    The pickup is a filter more than anything.
  • wrinkleygitwrinkleygit Frets: 264
    One thing I have always done to my Lp's is to rotate the neck pickup thro' 180 degrees to bring the pole pieces closer to the bridge ( this doesn't put the pups out of phase you need to swap magnets to do that ) to my ears it brightens things up a little & costs nothing to try.
    Isn’t this basically the Peter Green mod?
  • ICBMICBM Frets: 72616
    edited March 2018
    No, that needs the pickup phase-reversed as well.
    The phase is by far the bigger part of it.
