Stratocaster Volume knob - what is the best way to take it off safely?
  • MikeBMikeB Frets: 176
    Shoelace wrapped around the spindle. Gentley pull up either side. Sorted.
  • TeeByrdTeeByrd Frets: 159
    Feeler gauge with cloth underneath and lightly rock until the knob comes loose. Actually, now I’ve read that comment back, it sounds kinda pornagraphic! It’s does work, though!
  • prowlaprowla Frets: 4983
    A spudger or the blanking plate off a computer PCI slot (rest it on a cloth or hanky so you don't scratch the guitar surface.
  • robinbowesrobinbowes Frets: 3068
    munckee said:
    Strat54 said:
    I live in the country so we use baler twine, works a treat :)
    My preferred approach is my Father's:
    1. Hit it with a hammer.
      If that doesn't work...
    2. Hit it with a bigger hammer.
    Only if it breaks would we need baler twine to tie it back together.
    Is your dad from yorkshire?  Sounds a lot like the age old craftsman skills handed to me by my father...
    Yes! How could you tell? :)
    R.
  • VoxmanVoxman Frets: 4787
    edited March 2018
    Thanks guys - all done. I found a thin plastic ruler that, with a soft cloth to avoid scratching, I placed under the knob, & turned it carefully until it released. Put on my foam 'donut' and my volume knob now has a bit more resistance sufficient to stop it turning when I don't want it to.
    Had to be very careful about my wording here - if I'd have said I managed to pull my knob off and now its stiffer, goodness knows the posts that would follow!    tonguegif biggringif
  • rossirossi Frets: 1711
    i usually just slip a thin cloth under it both sides and yank it off .it comes easily ,and my case come up next week guv.
    QED - I rest my case!biggringif
    Was Googling for something else and came across this photo:
