Rig problem...
  • @hotpickups it could be the toggle switch in  your guitar.  Happened to me several times.  Take the back panel off your guitar,  use a small bit of lightgrade sandpaper to clean between the contact points on both sides of the toggle switch,  spray a bit of electrical lube to clean it out and hey presto it will be a good strong signal again
    Ok I'll try that too. Thanks
  • Any time this has happened to me it's been an intermittent cable fault.
    Really hard to diagnose, you just need to be methodical and pray it doesn't strike at a bad time!
  • I have a Rat pedal that does this occasionally - it's something in the pedals' internal switch wiring. Very disconcerting the first couple of times it happened, but easy enough to diagnose and fix
  • koss59koss59 Frets: 859
    I’ve had this before on a Dr.Z years ago, it was the input jack. Just needed a clean.
     A mate also had it happen on the jack of his fx loop.
    Might be worth a spray of servisol in all jack sockets.
    Facebook.com/nashvillesounduk/
    Of the guitar you mean ?
  • I've had a few of these...Gibson switches are a classic high resistance problem, play a big chord, all ok but then play softly and the sound goes on/off, jack sockets too where the guitar has been used then put away in a case then pulled out Friday night to the same issue, a few jack insertions sorted it.  Pedalboard with soldered EA cable to Hicon right angle connectors has been 100%.  If you have quite a few guitars this is a bit of a pain unless you have a through "maintenance programme", difficult with a life too!
  • JezWyndJezWynd Frets: 6150
    edited September 2018
    One more question. Is the volume drop a typical possible sign of valve wear like what Waz mentioned?
    I had a similar issue recently on my Ampeg head. New valves sorted it. It's usually the power amp valves going that give that symptom apparently.
    Blimey. It's relatively a new amp though and haven't used it that much :(
  • To me it sounds like bad power to the power supply unit for your pedals.
    Was you running off a crappy 4 way or anything like that?
  • ICBMICBM Frets: 72927
    A bit late to this, but if running the guitar straight to the amp fixed it, the problem is either in the pedalboard or the cable you were no longer using. It wasn't the guitar or the amp, so don't worry about those.
    Checking cables with a meter doesn't always show up a fault, you need to do it with a signal through it. Flexing the cable may well have cured it (at least temporarily) when you took it out of the pedalboard as well.
    No the amp input but also Fx loop jacks are also worth cleaning. It was the sort of thing that only happened occasionally so always seemed fine at home but volume wavered live.
  • hotpickupshotpickups Frets: 1823
    Ah that could be it. I do use a five or six plug gang bar
    Can you recommend a quality plug bar @meltedbuzzbox ;
    @ICBM ;How do you mean test it with a signal going through it? You mean if it works or not etc. It works at the moment :)
    hotpickups said:
    @ICBM ;
    By playing a music signal through the cable while flexing it to check for bad connections or shorts.
  • ICBM said:
    hotpickups said:
    @ICBM ;
    Ah right. Yeah done all that. All good now. Left the amp on all day and still couldn't recreate the scenario from last night when plugged the board in etc
    Poor connection in the toggle switch will cause volume drop, loss of most (but sometimes not all) of the signal, and potentially be intermittent.  It's weird, but a simple 5 min fix if its the cause.
    The Ampeg valves were Ruby's, 10 months old, with 1 - 2 hours daily use, never driven hard, home use only. Now replaced with EHX which I'm hoping will last a bit longer.
