Really hard to diagnose, you just need to be methodical and pray it doesn't strike at a bad time!
A mate also had it happen on the jack of his fx loop.
Might be worth a spray of servisol in all jack sockets.
Was you running off a crappy 4 way or anything like that?
Checking cables with a meter doesn't always show up a fault, you need to do it with a signal through it. Flexing the cable may well have cured it (at least temporarily) when you took it out of the pedalboard as well.
Can you recommend a quality plug bar @meltedbuzzbox
