The ones you'll see selling for £350+ are loaded with NKT275 transistors. People tend to use the NKT branding in the listing title to try and command a higher price and not make it clear they're not 275. If you check the completed listing the generic NKT versions usually fetch £220-250.
In blind testing there probably would be no real difference detected after a bit of tweaking on the settings but it's the rarity that people are chasing not the output.
