How genuine is the wear on this neck?
13»
  • VeganicVeganic Frets: 673
    NelsonP said:
    peteri said:
    why would you get that wear all at the second fret?
    E
    A
    B7
    D/F#
    Pretty common chords those.
    How come they have never played an F chord?
    The nut might be a bit high :open_mouth:
  • enjoenjo Frets: 278
    Veganic said:
    NelsonP said:
    E
    A
    B7
    D/F#
    I have a feeling they did - that wear looks similar to another guitar I've seen - the guitarist had long fingernails on the fretting hand which dug into the fretboard hence the placement of the wear relative to the string.
    enjo said:
    Veganic said:
    NelsonP said:
    E
    A
    B7
    D/F#
    The nut might be a bit high open_mouth
    So 1st finger barre= no fingernail contact. Got it.
    Veganic said:
    enjo said:
    Veganic said:
    NelsonP said:
    E
    A
    B7
    D/F#
    Exactly!
  • WolfetoneWolfetone Frets: 1479
    The blackened wear actually turned out to be finger gunk which was quickly removed by acetone. The guitar is all original with larger tone/vol pots. The machines are Gotoh. The finish is very thin almost nitro like.
  • robgilmorobgilmo Frets: 3581
    Lovely, any photos of all of it?
  • ICBMICBM Frets: 72598
    I still think your daughter will be put right off by that...
    It"s in pieces at the moment awaiting a deep clean and a set up. Not sure if the frets will take a recrown but I may as well try.
    I think that is just the cover story. We've all been there.
  • SteveFSteveF Frets: 539
    None of the pics work for me?
  • rossirossi Frets: 1707
    You can get Squier SE's  pack  strat from Gumtree for about 40-50 quid that with a decent set will play all day .Full size and sounds  half decent if you lower the ceramic pups .Add some good but cheapish   pickups and a Wilkingson  trem and its a keeper  for about 130  notes even less depending on pickups .
