Who uses 2 delays on their board?
fastonebazfastonebaz Frets: 4136
I've only used 1, but I'm thinking i could be missing out on a much lusher lead tone by having 2 delays, one short, one long.
What's the verdict? For those that use 2, does it sound a bit dissappointing when you go back to 1?
  • vizviz Frets: 10731
    edited January 2019
    I use 2 but quite often not together, so I could probably use 1 if it had tap tempo.
    See 2:20
    https://youtu.be/8B7hfx8Sgw4
  • TheMarlinTheMarlin Frets: 8025
    I’ve got 3!
  • LebarqueLebarque Frets: 3905
  • boogiemanboogieman Frets: 12434
    I’ve got three.  =) Polymoon, Time Factor and El Capistan. They’ve all got different features I like, but I generally only use two at one time.
    Short delay into long, or vice versa is really nice for ambient stuff. Sometimes you get a happy accident of the delay times beating against each other for cool weird effects.
  • fastonebazfastonebaz Frets: 4136
    See 2:20
    Oooh a carvin amp, is that a legacy3 perchance?
  • joetelejoetele Frets: 952
    I've got 3 and I'm about to add a fourth. I've been known to have five delays at one point. I'm sure others have more. Always nice to have lots of options for different sounds and pedal placements
    MUSIC: Pale Blurs
  • John_PJohn_P Frets: 2750
    Dm2 and el Cap.      Dm2 is set for very short and quiet delay and is on most of the time unless I’m doing some tight funky rhythm, el cap is set for a medium/ longer time with a couple of repeats that I’ll add for washy clean arpeggios or solos.
    I coole gig quite happily with just the longer delay but having the short one makes everything sound bigger.
  • EricTheWearyEricTheWeary Frets: 16303
    2 although not used in a rocktastic manner. But essentially short delay and long delay then the two together for something noisey/ ambient. But I would like a third for some modulated nonsense. A big box delay would probably make sense but the cost and the sub menus put me off.
  • fandangofandango Frets: 2204
    Flashback plus Caverns, and there's room for a third, having last year let go my Vapor Trail.
  • I've got two on my larger board - Carbon copy into the front of the amp and a Digitech DL8 in the loop:
  • impmannimpmann Frets: 12683
    Yep.
    On the board DSD2 and Boonar - plus a Line6 M5.
    But I also use a Mooer Ocean Machine for recording - incredible thing.
    My Line6 M13 has one scene where every button is a delay. The auto-swell delay into a ping pong stereo delay is incredible.
  • menamestommenamestom Frets: 4727
    I’ve got one atm, but will probably go to 2, something for slapback (Dm-2w or aqua puss) and something for long and modulated delays.
    (El Cap, MLj, MXR echoplex etc).
    Probably easier having 2 desicated than one with presets.
  • DesVegasDesVegas Frets: 4612
    edited January 2019
    I have one before reverb which can self oscillate and one post reverb (DL8) which also has a looper
  • CirrusCirrus Frets: 8495
    Rather than one short, one long, I quite like one clean, modulated digital & one thick, melting into lo-fi analogue.
  • I have five! lmao. Guilty pleasure.
    Bye!
    edited January 2019
    See 2:20
    No it’s one of Steve’s old Legacy 1s :)
  • robertyroberty Frets: 10896
    edited January 2019
    Yep an aggressive DD3 slapback followed by long delay tap tempo
    edit: here's DD3 slap followed by a DD7 on reverse mode, quite an extreme example https://www.dropbox.com/s/zlk62ih5c4k2fyt/delays.mp3?dl=0
    See 2:20
    Bloody hell that modded CE2 is lush
    I use blended 4th 5th mode on my whammy a lot too
    viz said:
    See 2:20
     That's awesome!
     That sounds quite synthy actually.
