How many types of drive do you need?
  • ColsCols Frets: 7112
    soma1975 said:
    Fuzz Face
    Treble Booster
    Light OD
    Distortion
    Nailed it in one.
  • TeetonetalTeetonetal Frets: 7815
    Thanks to amp having a good dirt channel and a footswitchable "hotrod" switch I don't need any drive pedals at all :)
  • stratman3142stratman3142 Frets: 2206
    Into a clean amp, whether it's separate pedals or a MultiFX unit, I like to have two drives. One for a light crunch OD and the other for more full-on distortion.
     I also like to have two levels of clean boost (post OD/distortion), with one at ~3dB for a slight lift (if needed) and one at ~6dB (e.g. for solos). Sometimes I add boost and back off the guitar volume pot to get different flavours of sound from the OD and distortion pedals.
    It's not a competition.
  • ICBMICBM Frets: 72662
    Four at most.
    Fuzz
    Overdrive
    Distortion
    Amp
  • CirrusCirrus Frets: 8495
    Dirt pedals tend to have narrower windows of applicability, I think. Amp distortion is a bit more reactive to playing style, so you can get it to work in more circumstances, but with pedals, what sounds great for one song/ part/ riff/ guitar can sound bad with something else.
    That's a huge generalisation, obviously, but it's what I found. Also doesn't mean that drive pedals are less good - I love them. But when I was getting drive mostly through pedals, at times I had a TS type, a more transparent low-gain, a mid gain, a high gain, a fuzz, a clean boost and I didn't think any of them were superfluous - even if I only used a pedal for one song in ten, it was there because I needed it for that one song.
    Freebird said:
    Sassafras said: mm
    OD-2 .for a little bit of gain.
    Pork Loin for a bit more.
    Fat Sandwich for even more.
    I feel hungry.
    So you should, it's a tasty combo.
  • Th4fonzTh4fonz Frets: 261
    The Duellist covers my needs for home use.  And I dont find myself searching for something better since I got it.
  • Grocer_JackGrocer_Jack Frets: 258
    Usually for gigs -  Bad Monkey with drive rolled all the way off for always on rhythm tone. Then Barber Gain Changer on low gain setting with gain half way for a extra boost for big chords, solos, loud bits etc.  Also on the board is a Les Lius which I use on 3 or 4 songs instead of the BM/GC combo. I could get away without the LL but it gives a nice contrast and a bit extra jangle for tunes that need it.
    For studio as above, but also use Fulldrive or Barber Direct Drive to get solos to really sing and also sometimes use a Black 65 as a different base tone. It's good to get a bit of contrast on a recording and I find that slight changes in tone create interest. Not sure anyone really notices though!
    - A Blues Breaker
    - A Tubescreamer
    (Both Duellist)
    - A Klon (RYRA)
    That's a very beige list of beiginess
  • KeefyKeefy Frets: 2323
    I currently run 3 on my big board, in this order:
    - Danelectro Transparent Overdrive v1 - cheeky Timmy Clone
    - Boo Instruments O/D-TS - blatant TS808 clone
    - Xotic Effects SL Drive - in Marshall Super Bass mode
    I could live with 2, in fact the Dano only recently replaced a wah pedal that I almost never used.
    The danger with stacking drive pedals live is in the varied volume levels the different combinations can give. Having three distinct pedal sounds gets me what I need without bending and twiddling mid set. My choices won't be yours so try what you can get your hands on.
  • monquixotemonquixote Frets: 17670
    It's ok if you are careful. You need to make sure that you don't have things like a clean booster slamming a MIAB into a clean high headroom amp. Turn off the pedals in the wrong order and you get a new insanely loud clean sound.
