I presume you disagree with my statement that playing nearer the neck or bridge really only works when using open strings or up to about fret 12?
Well, for my ears, that's true. For your ears there may be a difference even when fretting at the 22nd fret.
I also explain, in my own way, that I think the tone changes depending on how you play using your fingers, and you say you disagree, but then you go on to explain that you think the tone can change depending on how you play using your fingers, albeit with a plectrum in a hybrid style.
We both think where you play, nearer the neck or bridge, and how you pick/play, affects the tone.
It seems to me, that you think you disagree with me, but in fact you agree with me.
The difference is clear,
And I also know, with much enjoyment and pleasure, that a master guitarist is playing them both.
Sad to say my phone auto corrected to moar, from 'more'.
Pretty lame. I'm now discounting my opinion and going to say tone is blues and fusion played on vintage style amps with vintage style guitars and pedals made by hand.
I don't believe it, but in the face of my phone's autocorrect, I think it's the right thing to do.
I know the vast majority of fingerstylists/hybridists(?) use nails. I don't, as I don't like the 'tone' nails give. I never said, or implied, that I think that no-one else should use nails.
Whether you believe me or not, I can hear a difference when I use my fingers at different angles, especially with a clean amp.
I made no mention of pickups, as I didn't think PUP choice needed mentioning, as playing nearer the neck or bridge also includes playing nearer the neck or bridge PUPs. I also didn't mention where the guitar's tone pots or the amp's tone pots are set, as playing nearer the neck or bridge has an affect on the overall tone no matter where those tone pots are set.
Our positions are really not as different as you think.
As a case in point Billy Gibbons has a 40 year+ recording history. So he has used a warm, crunchy Les Paul tone, brighter telecaster tones, clean chorused tones, the distorted and modulated type tones of the hit singles period, the more inyerface tele type tones of later years and a bunch of others no doubt. It is recognisably Billy through out due to musical context, phrasing and technique. His current live rig contains a shit load of processing gear so, yes, the idea that you can hear his string gauge is verging on the ridiculous ( and in his simpler gear days he didn't use such light strings anyway).
I suppose that does lead back to the idea that Tone ( in a very broad sense) is with the player and not with the gear.
http://www.youtube.com/watch?v=H13zo8iEbeg&t=6m0s
