Warming up a Strat
  • SassafrasSassafras Frets: 30320
    Gas mark 3.
    30 minutes per pound.
  • guitars4youguitars4you Frets: 14659
    Try a curly lead :)
    - Yes a tone sucker, or at least hi end sucker - There was an American article some months ago measuring the capacitance of those 'Hendrix' era curly leads - The idea was you needed to put a cap inline to replicate the lost of highs from such a cable - Assuming you still used a good quality straight cable - They obviously implied that such a cable had some impact on the 'Hendrix' voice
  • FunkfingersFunkfingers Frets: 14719
    edited May 2019
    There appear to be two Discussions on this topic by the same thread starter. The other one has received more replies.
  • springheadspringhead Frets: 1625
    The Hendrix style player who's kit I look after only uses curly leads, between pedals too as per Jimi gig photo's.  Into a bright Superlead it does sound very good.
  • crunchmancrunchman Frets: 11504
    A superlead can take your head off though if you don't tame the top end.
  • EricTheWearyEricTheWeary Frets: 16327
    IIRC Jeff Beck always has the volume knob on his strats at 8 or 9 just to take that top end off.
  • KittyfriskKittyfrisk Frets: 19288
    Have a read of this https://guitar.com/guides/essential-guide/ultimate-guide-strat-tone/
    As to 'The bridge literally sounds like a telecaster', standard Stratocaster bridge pickups are always more shrill/ice picky than a Tele bridge IMHO  ;)
  • GreatapeGreatape Frets: 3664
    edited May 2019
    The only thing I have in common with him.
    Does it have a treble bleed? Clip it out.
    If pickups are too low or too high, that will affect things.
    Try a different pick. Some add way too much plink to the front end of the note.
    Award Session make a cable that rolls off some highs.
    Maybe the cap value needs to change.
    If no joy, try a warmer pickup - another vote for V60lp.
  • mrkbmrkb Frets: 7000
    sweepy said:
    Try a brass grounding plate on the bridge pickup, not 100% convinced but it’s cheap and worth a go
    I thought it was a steel plate that was recommended - same as a tele pickup has. Does a brass plate do something different?
    Karma......
    Ebay mark7777_1
  • 5redlights5redlights Frets: 317
    Apparently a brass trem block warms up the sound, so could try that?
  • RandallFlaggRandallFlagg Frets: 14002
    I had that trio of pickups is a CS 60s Strat a few years ago, they were Abby Ybarra hand wounds though. I actually preferred the Texas Special in the bridge over the other 2 as I thought it a fatter warmer sounding pickup. I do like to roll down the tone to about 6 ort so on a Strat bridge pickup when using overdrive though.
  • RolandRoland Frets: 8835
    Duplicate threads merged
  • PonchoGregPonchoGreg Frets: 764
    I think part of it will be the actual guitar too - is it alder & maple board?
    I can recommend the tonerider classic blues set for a cheapish option. No shrillness in my strat, but it's a rosewood board and pretty heavy so naturally a bit mellower
    Click here to see me butchering some classic solos!
  • cbakaycbakay Frets: 67
    If ur main amp is the fender, clip the bright cap and try a cannabis rex speaker. I had the same issue and now it’s great combo (but with a drri65)
  • Fishboy7Fishboy7 Frets: 2249
    Could try dropping a single coil size humbucker in there.
  • soma1975soma1975 Frets: 6981
  • VoxmanVoxman Frets: 4787
    edited May 2019
    Have a delta tone circuit mod done to give no load tone control on the bridge pickup.
