Gig bags question
RockerRocker Frets: 5006
Would the same gig bag be safe/big enough to carry a Strat or a Tele or a Les Paul?  Lack of space prevents getting a second gig bag. Thanks
Nil Satis Nisi Optimum
  • darthed1981darthed1981 Frets: 12175
    I've got a couple of PRS gig bags which I use for everything.
  • ftumchftumch Frets: 691
    Almost certainly big enough. Imo a les paul is never safe unless its in a decent hardcase. Ive had three gibson neck breaks, two of them in decent padded gig bags.
  • Standard gig bags are fine for Strat/Tele/LP/SGs etc. Be warned though, I'd assumed a Jazzmaster shape would fit too, but alas I had to fork out for a bass gig bag to fit the extra length of a JM. Annoying!
  • ICBMICBM Frets: 72853
    Padded is not enough for a Les Paul, you need a neck support at the minimum. I wouldn't carry a 'good' Les Paul in anything less strong than a Mono or Fusion at all, and even then I'm not sure.
  • TimmyOTimmyO Frets: 7639
    Having used a Mono Vertigo for some time with a PRS and a Les Paul (on those occasions I bag was more convenient) I think as far as whiplash protection goes it's as good as a case - I'm always a bit twitchy about it getting stood on or an amp.out on top of it in a car/van - just the lackmof a rigid outer skin.
    But for headstock break from getting dropped/clonked I can't see that it's any more risk than in the case a LP comes in.
    Red ones are better.
    I think the headstock end is still slightly more flexible than a hard case, but not much. It's the lack of a fully rigid outer skin as protection against bending that makes the difference - for whiplash protection if it falls over I'm sure the hard case is actually worse, since it will transfer much more of a hard knock to the instrument.
    I happily carry my vintage Rickenbacker 4001 around in a Mono Vertigo all the time, and I have no fear about it at all.
  • peteripeteri Frets: 1284
    I use the Mono cases all the time for my Les Pauls, Strats, Teles.
    To be honest - I feel happier with my old Les Pauls in the Mono than anything, I can also recommend the twin case - I've used that a lot.
    They're not cheap, but worth it
    You can safely carry a Strat or a Tele around in a bin bag.
  • KittyfriskKittyfrisk Frets: 19207
    You aren't wrong  https://www.thefretboard.co.uk/discussion/comment/2245713/#Comment_2245713
