Vintage Fuzz that works with humbuckers
  • soma1975soma1975 Frets: 6730
    p90fool said:
    A fairly low value treble pass cap on your guitar volume helps radically when using  fuzz if you want it to clean up nicely.
    Hmmm, it's always been my experience that treble bleed caps were the enemy of fuzz face circuits.
    @JMP220478 that is pretty cool, see my post above about what I’m shooting for, sounds like the velvet fuzz might be a contender??
    Based on your sound example - I would be inclined to agree with @Grunfeld - velvet fuzz in tight mode is meant to mimic a full stack with fuzz and big mode is a big muff and has a fair wedge of bottom end ..
    I tried to mimic your guide tone with velvet in big mode and an eq pedal into a AxeFx with a JTM profile n its kind of - but is the Axe profile n cab same as yours ? Do you want to run an eq to roll off that huge bottom end ?
    Id go for the try out option on the BM personally
