However it still bothers me so to get round it I just stick to single amps. I have a volume block setup with a scene controller attached to the level. I can go from clean to full on gain just by varying the amount of signal the volume block lets through to the amp. It is in effect working just like backing off the guitar volume to vary the gain.
It works really well. I use the Mesa Mk II C++ amp for all my sounds.
Switching lag isn't an issue anymore as the others have pointed out - it's not completely gone but is negligible. I tend to stick to a preset per song and switch scenes within that preset.
I'd thoroughly recommend checking out Austin Buddy's preset packs, they gave me a great start in giving really well set up presets for each amp and a well-matched cabinet, and usually a drive pedal or two. He's also got a great video on setting up the AX8.
I personally have an axeXL so converted them with fractool. Thought I’d mention it if anyone is interested?
