sc relic junior build for Scott
13»
  • DanielsguitarsDanielsguitars Frets: 3297
    oh yes it's alive, i made a nut for it rigged up a trapeze and got the wraparound where i wanted it so it intonates well, i always hate drilling for these, the other thing that is really annoying is the slop in the bridge and post size, what happens is the wraparound will pull to the treble side so you have to drill the bass side post over by about a mm so it doesn't slide down too far and the strings look off on the fretboard
    I think it's close enough now
    I've used gotoh sd90 tuners which i think are better than klusons junior ones, the bridge is a kluson and studs and bushes, the bushes are the coarse ones 30mm long, they won't move like the old ones
    www.danielsguitars.co.uk
    (formerly customkits)
    edited July 2019 tFB Trader
    The dc has been worked on today which was pickup route, fret level and crown rolled fretboard and do the fret ends, new nut will be made tomorrow and it's sand them and send off to scott to work his magic
