Fairy Liquid, or laundry detergent are not suitable alternatives!
Do keep us updated on what it actually was.
Seriously.
My mum and step dad are just like me.. If theyre gassing for something, ANY excuse is the reason to pull the trigger..
They've got a car each, this one being mums. Step dads got a Peugeot 3008.
Peugeot is for their European archery tours with all their kit and the dog, and the Cab is for cruising the Alps on non sporting holidays.. theyre late 60's the pair! Admirable really. I used to tell them to slow down, but my step dads had 2 heart attacks and my mum been through cancer on top of most illnesses, losing a kidney, a divorce..
Hell, you do only live once. Now I urge them to go nuts every day!
But as retirement looms my step dads been coaxing my mum into part x'ing for a newer cabriolet model thats also petrol as opposed to diesel, so when these laws come in they can still drive into Leyton to watch orient play or something.. and it might last a little longer before they go down to one car.
My mums a motorhead like me, she wants to sell both cars and buy a merc convertible.. My step dad's a utility kinda guy, must have room for the dog, all their archery kit, all their friends, all the luggage, room to pick up the shopping on the way back, a high driving position, oh and it MUST come in silver or grey... ugh.
Anyway, I can hear him now..
'Nope, its a goner, cheaper to get rid, come on look, I've found a Golf in red and low miles at the local Vw, only live once, you deserve it...' haha..
Seriously I bet I get there Thursday after work and its in the process... lol!!
If people can't be arsed to read anything about how to use and maintain this very expensive machine they've just bought, they deserve everything coming to them.
hopefully its one of the other excellent pieces of advice in this thread
If the screen is in a real state I just use a bit of meths on a cloth.
My old 3 series did it too, but easy on an E46, just take the bottle out, remove pump, and clean filters, 10 minute job.
I've love to know the logic of putting the bottle behind the inner wheel arch liner, apart for the obvious, £200 dealer job to clear any problems. It isn't as though there's no room under the bonnet for it.
Then tracing the tube I found it was squashed flat between two large plastic components. Shortly before I’d had the car serviced and a new battery fitted. Removing/installing the battery meant removing the whole plastic section at the base of the windscreen! In putting it all back the technician obviously didn’t feed the tube through the small hump intended for it but instead squashed it flat. Once the offending parts had been unscrewed and the tube moved to its correct position in the hump the problem was solved. No I won’t be going back to that guy.
I traced the initial filler pipe by eye down to the wheel arch where a bigger reservoir exists but quickly gets obscured and is unreachable off a ramp with bits in situ...
Can you hear the pump when someone activates the switch and you put your head under the bonnet ? if not get a meter a check for 12V on the pump connector when the switch is activated. If the 12V is there but the pump doesn't spin then you need a pump or the switch is fucked ... in that case check for volts on the switch and check the switch is closed circuit when activated
If the pump spins but there's no action through the pipes then you might find a leaf has got into the bottle and is blocking the exit cos the pump sucks the leaf against it. Happened on my Transit, had to take the whole washer bottle out of the lower front.
Tbh I wouldnt have been able to do much, but I suspected the pump as I couldnt hear a peep with my head right up under the hood, and the washer stalk being pulled.
Anyway, VW came back and said that the 'software in the stalks/column needed an update'... wtf. But ok. Is that for real?
+ the pump was FUBAR too.
Maybe the pump going caused the 'software' to fuck up.. No idea, can't be a coincidence that 2 related aspects both went though.
Unless the garage wasn't truthful about this software error.. can't say I know much about it though.
I remember once though my mate had an Audi A3, and we went to a place that could hook it up to their computer and adjust things.
Can't even remember what my mate wanted done, but pretty sure it was something to do with a HID kit he had installed.
Anyway, 5 minutes into the drive home and we notice that pulling the handbrake caused his headlights to come on or something to that stupid effect.
So we went back and the bloke was like 'oh must've put the wrong code on' and 5 mins later he'd uploaded the correct wizardry to the car..
Was crazy.
