The 355 is very Bernard Butler too!
The 355 is Freddie Kingtastic!
Hate chewed head stocks on vintage gits.
If you're interested, mine had the adjustable bridge - Feline made a new bridge for me which is a drop in part (meaning takes two minutes to get it back to original with no damage at all) and improved the sound quite a bit (louder and a bit more rounded to my ears).
Once in a while I fancy a Martin, then I play the J45 and - it's all you need!
@NorthernGooner I expect it will have the narrow nut although there are some exceptions. I had a 68 J200 with standard nut but my assumption is narrow.
I remember the 65 J45, I found it for you
Thanks for the tip on the bridge, got a couple of other things I want done as the frets need attention and I want a pickup installed (only because it’s already drilled for one) so may get it all done at once.
Looks like a 1 piece back on the J45 as well.
