Straty Gibson style guitar
Hi all,
I've come to the realisation that ergonomically LP's suit me better than Strats. I like the shorter scale length, neck angle, carved top and bridge position/height. What I miss however is three single coils..
Does anyone know of a guitar that straddles the divide? I know the only thing that sounds like a Strat is a Strat but I'd be prepared to compromise..
Si
«13
    PRS - as a compromise ?  509 looks very versatile ?   or the DGT with arguably the best coil taps on a HB guitar ?
  • Thanks @JMP220478 ;
    Shame the 509 has a slightly longer scale length...
    Si
  • EmielEmiel Frets: 215
    What about P90's?
    Two examples...
    Gibson Gary Clark Jr SG.
    Asher Marc Ford signature
    Oooo, I like that Asher guitar.
  • crunchmancrunchman Frets: 11493
    I think Warmoth do conversion necks for a shorter scale, but that won't change the neck angle if that's an issue for you.
    Book yourself on a Crimson course and build yourself one?
  • rze99rze99 Frets: 2385
    Yes the SG with P90s will get you most of the way there.
    I have a couple of les Paul’s with P90s and the neck pickup especially can do a quasi Strat sound with the volume pulled back a little. Needs 50s wiring/treble bleed. The Brick In the Wall solo was famously a Les Paul with P90s. Not a Strat.
  • DanielsguitarsDanielsguitars Frets: 3302
    That's exactly why I'm making a telepaul to satisfy myself with some fender tones, i like LP body shapes set necks and the shorter scale, hot tele bridge staple p90 neck is what I'm going for, alder body flame maple neck
    If i was going more strat I'd stick a split coil humbucker in the bridge and 2 60's strat pickups in it, I'd also have a volume on the bridge with a volume controlling the middle and neck, same as tones
    www.danielsguitars.co.uk
    (formerly customkits)
  • impmannimpmann Frets: 12697
    PRS 305? I have one (I bought it instead of a CS Strat - genuinely *that* good). It still has the Fender scale length but the body shape is more Gibson than Fullerton. The difficulty may be finding one that isn't expensive...
  • merlinmerlin Frets: 6808
    edited October 2019
    Gibson S-1
  • Part of my quest to satisfy Fender tones (without buying a Fender) was to fit single coils into a Gibson style build. These pickups are single coils built into humbucker housings. I had them specced as trad Fender strat PUs.
    But (and its a big but), it still doesn't sound anything like a Fender. It sounds good, but the experiment failed nevertheless.
    I sometimes think, therefore I am intermittent
  • oh_pollooh_pollo Frets: 873
    edited October 2019
    Might be difficult to find, but PRS did a Custom 22 Soapbar around 15 to 20 years ago.  It's long since discontinued, but might be worth a look if you can find one:
  • Dont suhr do a strat with a gibson scale length?
  • Philly_QPhilly_Q Frets: 23479
  • It’s the pitched back neck that’s the tricky bit. I suppose you could get a conversion strat neck and get a luthier to modify the neck pocket?
  • In the 1990s Gibson did a les Paul with hsh pickups to try and do the strat tones. I think iGibson called it M3 electronics. Dunno if it’ was any good or not, but thought I’d put it out there.
  • LewyLewy Frets: 4307
    Yes it was the Studio Lite M-III
  • KittyfriskKittyfrisk Frets: 19235
    One brand that is usually under the radar, is Godin.
    The SD 22 & 24 (fret) are a strat/LP hybrid, with Gibson scale, HSS (splittable/tappable HB) and a really nice neck.
    A quality instrument at a ridiculously low price point.
    Worth a look  ;)
  • bbill335bbill335 Frets: 1391
    Check the non-reverse firebird thread. Those are in every way the midpoint between fender and solidbody gibsons
  • JalapenoJalapeno Frets: 6405
    Gibson MIII ?
    Feedback
