Finished Pics! Dreadnought Acoustic Build - Black Limba
1234568»
    BigMonka said:
    A beautiful guitar Andy and sounds fantastic (amazing playing clearly helps there too!).
    I presume that he mainly uses open tunings for that type of playing - did you make any design adjustments to take that in to account, or to cater for the percussive bits in his playing?
    Those two clips he just used a drop D on the 6th string.  Amazing player.
    No changes made for the percussive bit - acoustically, good percussive sounds usually means good string sound too.  He doesn't actually hit it that hard.  And, after all, it is finished with Ronseal Hardglaze - knew there was a reason for always using that! :)
     It was a consideration for the pickups, though, and both the mic from the Anthem system and the Pure Mini transducers work well in that respect.
    Just lovely, excellent work sir ! B)
    Feedback
    Thanks, @Jalapeno ; :)
  • TheOtherDennisTheOtherDennis Frets: 2011
    edited October 2019
    Having seen it in the flesh (though before it was fully finished, but still...), I can confirm it is every bit as good as everyone thinks it is.
    If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
    Thanks, Dennis :)
    Andy
  • rsvmarkrsvmark Frets: 1383
    Sounds as good as it looks! (I wish he wouldn’t hit it though....;-))
    An official Foo liked guitarist since 2024
    edited October 2019
    "Yes, I were there. I seen it.  But it was only gentle hitting, yer honour...honest!"
  • IvisonGuitarsIvisonGuitars Frets: 6841
    Inspirational! Superb work Andy and thanks for a great thread :)
    http://www.ivisonguitars.com
    (formerly miserneil)
    Thank you very much :)
    I know this is an old thread, but I did promise to post the link when Matt finally got round to doing a proper video playing his dreadnought.
    And here it is.  As always with these things, best through headphones :)
    https://youtu.be/8SCNbnmBY2Y
    Assuming you do like it, remember to 'Like' it - pro & semi-pro musicians need all the help we can give them in these unusual times ;)
    Thanks for looking
  • CorvusCorvus Frets: 2929
    Very nice, sounds lovely..! such a nice build too..
    Thanks @Corvus ; :)   He's a great player, isn't he.  Lovely Pat Metheny composition too :)
    Hi
    I said that I would ask Matt to do a recording of a direct comparison between the K&K Pure Mini and the LR Baggs Anthem.
    I've just kicked off a thread in the Acoustics section here:
    https://thefretboard.co.uk/discussion/180534/k-k-pure-mini-and-lr-baggs-anthem-direct-comparison#latest
    but in brief, because there are both systems installed and two independent outputs, we have the almost unique opportunity to hear the two systems during the same performance
    The video is here:
    Oh - although modesty almost makes me hesitate to mention it -  he says some really nice things about the guitar at the end :)
    Yours humbly
  • TTonyTTony Frets: 27639
    He's not a bad player!!
    Guitar sounds beautiful.  Warmth, lots of body, clear, precise notes ... great player with a great guitar.
    That one turned out alright.
    :+1:
  • TJT1979TJT1979 Frets: 188
    Just found this thread. Beautiful work. Huge thanks for taking the time to post this.
