Those two clips he just used a drop D on the 6th string. Amazing player.
No changes made for the percussive bit - acoustically, good percussive sounds usually means good string sound too. He doesn't actually hit it that hard. And, after all, it is finished with Ronseal Hardglaze - knew there was a reason for always using that!
It was a consideration for the pickups, though, and both the mic from the Anthem system and the Pure Mini transducers work well in that respect.
Feedback
Andy
"Yes, I were there. I seen it. But it was only gentle hitting, yer honour...honest!"
(formerly miserneil)
And here it is. As always with these things, best through headphones
https://youtu.be/8SCNbnmBY2Y
Assuming you do like it, remember to 'Like' it - pro & semi-pro musicians need all the help we can give them in these unusual times
Thanks for looking
I said that I would ask Matt to do a recording of a direct comparison between the K&K Pure Mini and the LR Baggs Anthem.
I've just kicked off a thread in the Acoustics section here:
https://thefretboard.co.uk/discussion/180534/k-k-pure-mini-and-lr-baggs-anthem-direct-comparison#latest
but in brief, because there are both systems installed and two independent outputs, we have the almost unique opportunity to hear the two systems during the same performance!
The video is here:
Oh - although modesty almost makes me hesitate to mention it - he says some really nice things about the guitar at the end
Yours humbly
Guitar sounds beautiful. Warmth, lots of body, clear, precise notes ... great player with a great guitar.
That one turned out alright.
