Thanks!
If you're sitting close to your cab at home, in the optimum listening position, the loudness should barely be different - but they will be louder out in the room.
We weren't planning to do a 210 but there's nothing stopping us if there's enough interest!
Mmmmm indeed!
Or is the issue that moving from one speaker to two actually increases the directionality by a bit along one axis?
Not being critical, I'm just curious as to how the mechanics of doubling the speakers works with regard to the AVD slot.
Trading feedback here
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
There is just no need for it - the large size is a generally 1970s/80s trend to make them visually impressive. Look at an original 1960s Vox AC100... only 19" wide, and even at that they could have made it slightly smaller. And then compare it to a 1970s Marshall 'large box' 50W head - which is about half totally wasted space.
36lbs or 16kg if you prefer the metric system. Full Marshall head width!
Rear view for total WTF is going on there?!!!
The physics of that just made my head explode. I'm not even going to ask
Us guitar players dont; use speakon stuff.!
Jack goes in the middle of the speakon.
(That's the back - the front looks much more normal!)
https://barefacedaudio.com/products/uprising-212v
Maybe with a G12-65 if it will fit.
