Line 6 HX Effects one expression pedal for Wah AND Volume
oktorocktooktorockto Frets: 86
I have two expression pedals connected to the HX Effects. I have the wah set so it is switched off when in the heel position and switches on when you move it. I use the other expression pedal for volume. Ideally I would like one pedal to do both jobs - mainly to save space and weight. I have looked at the Mission Line 6 Helix pedal with toe switch but am told this does not work with the HX Effects apart from the fact it is really expensive and weighs a lot. Currently I use two Roland EV5s and those alone have saved 2Kg from my old dunlop wah and volume pedals.
I was wondering if I could use one pedal by building a toe switch into the pedal so that it would control an A/B box (I would put this inside the single expression pedal) With the switch in one position it would connect the pedal to expression input 1 for the wah and with the switch in the other position it would direct it to expression input 2. I would have to do something like set the wah to turn off when it stays in the toe down position for one second - then I could press the toes switch and get the volume control perhaps.
The only other way I can see it is to use a built in Audiofront MIDI expression unit to control the switching of the effect with a toe switch but I am loathe to add more things that need power to my pedalboard.
Any help much appreciated.
  • SnagsSnags Frets: 5403
    I have no idea if it would do it, but the Boss EV-30 has two inputs for pedal 1 and pedal 2, so in theory there's the possibility that you could assign the pedal outs independently but have a single controller. The only bit I can't figure out is how you tell the pedal of the two outputs to use at any given point in time, particularly on the fly.
  • shuikitshuikit Frets: 224
    This looks like it's halfway to what you're trying to do, might be helpful.
    https://line6.com/support/topic/26725-toe-switching-with-an-external-exp-pedal/
    Funnily enough I found that about an hour before you posted your reply. it uses both EXP inputs but I reckon you can wire with a resistor so that a switch just fools the one input that the heel is down - set the wait time to low and there you go - off/on switch. Will have to investigate in the new year.
  • Tried experimenting with a resistor but it looks like the HX FX is waiting for a sweep of values to head to 10k and then use that as a signal to turn off.I think this is the answer: https://www.audiofront.net/MIDIExpression.php
  • thomasw88thomasw88 Frets: 2330
    can't you just assign one switch on the HX  ie off = Volume pedal, on = wah? appreciate its an extra click but in the scheme of things isn't that complicated?
  • Needs to be like a real wah
  • handsomerikhandsomerik Frets: 1007
    edited January 2020
    You need the mission line 6 Helix expression pedal. I believe it has 2 inputs plus a toe switch to switch between the 2 functions. So it should be able to go from volume pedal to wah pedal when you rock it foward and press the switch.
  • Hi - seen that but trying to achieve this by only using one of the inputs so will have to be MIDI. Oroginally I was interested whether you could use a switch to fool the input into thinking the pot was at full heel travel by showing it 10k with a switch so that when it is set to tun off at heel position it would do so with a switch - but I don't think it will. The only other way of doing that would be for it to be switched at the heel position perhaps but I think that would be hard to activate.
  • TeleMasterTeleMaster Frets: 10265
    I use a Dunlop Volume X. Much better than the Mission stuff as the pedal sweeps better and more naturally. I'm selling a spare if you want one at a good price.
  • I use a Dunlop Volume X. Much better than the Mission stuff as the pedal sweeps better and more naturally. I'm selling a spare if you want one at a good price.
    Interesting - could be the answer - fit a switch to this and use that for wah on and off - how much do you want for it?
    edited January 2020
    I'll take £60 delivered if you want. Comes boxed. I can send you pictures and show you my feedback thread here and ebay profile (over 400 feedback 100% positive, mostly selling). Let me know!
