Making, but not a guitar
TTonyTTony Frets: 27601
edited January 2020 in Making & Modding
Maybe this should be in OT rather than M&M?
Most of the offcuts end up - eventually - on the fire one way or another.  But some get used for other things.
Like making a Xmas present for MrsTT ...
Bit of timber with corners & edges rounded over, and oiled.  Add some test tubes, held in place with pipe clips, and a few Swarovski crystals to make it look posh, and a hanger for the wall.
Wander around the garden collecting bits of plant, add water and bits of plant to each test tube, and there's a bit of living wall art.
  • RolandRoland Frets: 8714
    Ah, the Christmas present thread. Can anyone join in?
  • TTonyTTony Frets: 27601
    Looks like a load of old bowls @Roland???
    Walnut.
     Yew, turned wet, and then re-turned once dry.
    Wild cherry turned wet so that it distorts as it dries. There a musical joke there somewhere.
    Yew, with a purple fault line across.
    Wild Cherry, turned dry.
    Yew, turned wet so that the sap colours in red.
    I would have guessed the Walnut, but not the others.
    Is that the Wild Cherry one at the front - light coloured in the main but with the dark grain running through it?  Nice!
