ICBM - I've never had problems with angled springs , but don't mind if they are straight either, just that angled gives a longer path and more tension.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Then you just need it a little tighter.
Ive ordered some FR Original clamps just to be on the safe side as mine are showing signs of wear. Also they’re chrome which will look badass on the black hardware.
They also have the great advantage - at least a proper-quality one does, some cheaper versions aren't quite as good - that once set up correctly and with everything locked down tightly, they not only stay in tune perfectly, they never need adjusting again either... or at least not unless/until the knife edges and the locking clamps do eventually wear.
Even 80s stoners could work those out.
They offer substantial mass and clarity compared to the cheap cast ones, and even over the standard German made brass ones. comparison of size below:
Either that or you've got the springs in a fan and they're sticking on the claw hooks .
I've greased the knife edge - changed the 2 springs (Ibanez Edge Zero 2) and replaced the trem posts - it's a little frustrating
