Non-stick pans, my arse !
Emp_FabEmp_Fab Frets: 24377
Does anyone have a recommendation for a non-stick frying pan ?  Everything I've tried has always failed within a year or two, and they never see the inside of the dishwasher - always cleaned by hand with just water and Fairy and a nylon brush.  Never seen a metal utensil...    I'm wondering if I should give up on good quality onces and just buy cheap shit and replace it when it fails.
«13
  • octatonicoctatonic Frets: 33804
    Are you having some sort of breakdown?
    4reaction image LOL 0reaction image Wow! 9reaction image Wisdom
  • Jez6345789Jez6345789 Frets: 1794
    I keep just a small non-stick for frying eggs so you can use the barest amount of oil and get good results.
    For everything else and years in a pro kitchen what is non-stick and why do you need it, just prove Omelette pans with salt from time to time and don't wash them.
  • Emperor_Trumpulous strikes again!
    Bye!
  • robgilmorobgilmo Frets: 3503
    How do you do that?
    I reckon Emp is burning his pans.
  • Actually a non stick arse would be a great benefit , say goodbye to those days when you seem to be wiping infinitely but still seeing colour on the bog roll
  • RobDaviesRobDavies Frets: 3067
    Without entering too far into the realms of Mumsnet...... Scoville Neverstick pans are very good.   Only got them just after Xmas so can’t comment on their longevity, though.
  • fields5069fields5069 Frets: 3826
    Th best type I have used is the pebble-dashed, speckled ones. Ours had no chips after 6 months, however the steel disc on the bottom delaminated. It seems there's always something to go wrong in these pans.
    Some folks like water, some folks like wine.
    My feedback thread is here.
    And yes I guess the answer is to keep a cheap small pan for fried eggs and not use non-stick otherwise, although some white fish will happily stick and disintegrate when cooked in pretty much anything.
  • KalimnaKalimna Frets: 1540
    https://www.seasoncookshop.co.uk/index.php/brands/scanpan/scanpan-ctx-pans/saute-pans/scanpan-ctx-saucepan.html
    We've had one of these for a couple of years, and still non-stick. Never in dishwasher, but gets a lot of use. Not cheap, but it seems to  last well.
  • NikcNikc Frets: 627
    Consumer product in replacement shocker ;)
  • francerfrancer Frets: 369
    A bad wokman always blames his tools.
  • munckeemunckee Frets: 12400
    Cast iron with ceramic coating seems to be the least sticky and easiest to clean.
  • Emp_FabEmp_Fab Frets: 24377
    It's exactly this one that's started to stick on me!!  Never stick..... My arse!
    Yes
    Cheap ones from IKEA for us.
  • Danny1969Danny1969 Frets: 10427
    Did you season the pan before you used it ?
    https://www.stonefryingpans.com/season-a-nonstick-pan/
  • RaymondLinRaymondLin Frets: 11879
    A seasoned carbon steel pan, it will outlive all of us.
  • VimFuegoVimFuego Frets: 15551
    dunno what brand they are, but couple of years ago  mrs f spent ages researching frying pans, ended up buying 3 fairly expensive ones (she thinks they're called mastercraft). From day 1 they've been shit. Unless you cook really carefully with them, basically they're completely non non stick. It was so bad, the smallest one basically failed after about a month (the coating came off). So don't buy them.
    When she was in hospital for the 1st time and I was spending all day there and was basically living off bacon and sausage sarnies, I ended up buying a cheapo one from the supermarket. Think it was about 5 quid and it's still fine. So my tip is buy cheap shit.
  • JAYJOJAYJO Frets: 1527
    I have a brand new non stick frying Pan under my pillow just in case a Burglar breaks in. He may want me to rustle him up some Egg and Bacon before he leaves.
  • SassafrasSassafras Frets: 30296
    Non stick pans suck.
    I use cast iron pans that stay non stick once they've been properly seasoned.
    You still have to use oil when frying so I've never seen the point of non stick pans.
    And I don't like the thought of eating little bits of tefal even if it is supposed to be chemically inert.
