They look lovely.
However - I have to raise the issue of the tremolo arm. It appears that you haven't used the Callaham/Kev Hurley system of a nylon sleeve in the block to eradicate slop. Whilst I accept that this is period correct, so are 13 gauge flat wound strings... neither are particularly good for today's player.
Can I suggest - nay, implore you - to adopt such an upgrade to your clearly otherwise well made Strat Trem blocks. Slop in the arm is hideous, unmusical and unnecessary.
I like those hardtail bridges with Highwood saddles!
Have to confess I didn't initially notice they were 5-string, I just thought the string spacing was very narrow....
We have discussed the teflon issue but feel it's not needed at this point with how our ones are
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I've had a multitude of Strats over the past 40+ years. Slop has never been a problem. I just remove and discard the small spring from the block... and wrap a small amount of PTFE thread tape around the thread on the arm.
We will add some standard thickness blocks in steel too for customers whose guitars wont accommodate a wider block without modification.
