Fat Cat Guitar Components ...bridge parts
  • FunkfingersFunkfingers Frets: 14522
    Also, very interesting. :)
  • Love my Steel trem block on my Squier Strat! Made a huge difference to the sound on it.
  • impmannimpmann Frets: 12669
    Jonathan,
    They look lovely.
    However - I have to raise the issue of the tremolo arm. It appears that you haven't used the Callaham/Kev Hurley system of a nylon sleeve in the block to eradicate slop. Whilst I accept that this is period correct, so are 13 gauge flat wound strings... neither are particularly good for today's player.
    Can I suggest - nay, implore you - to adopt such an upgrade to your clearly otherwise well made Strat Trem blocks. Slop in the arm is hideous, unmusical and unnecessary. :)
  • Philly_QPhilly_Q Frets: 23017
    I like those hardtail bridges with Highwood saddles!
    Have to confess I didn't initially notice they were 5-string, I just thought the string spacing was very narrow....
  • FelineGuitarsFelineGuitars Frets: 11619
    impmann said:
    Jonathan,
    They look lovely.
    There is ZERO slop in the arm fitting using the arm supplied - very precisely cut.
    We have discussed the teflon issue but feel it's not needed at this point with how our ones are
  • impmann said:
    Jonathan,
    They look lovely.
    I've had a multitude of Strats over the past 40+ years.  Slop has never been a problem.  I just remove and discard the small spring from the block... and wrap a small amount of PTFE thread tape around the thread on the arm.
    Packaging came in today (yay)
    Just a heads up that we have added a couple of lines
    We have added "in-between" depth blocks for the Floyd Rose Blocks : 40mm and 35mm
    We have a block for the Jackson JT6 tremolo
    We have a block also for the Floyd Rose Pro Model that needed the mounting bolt holes offset to fit without fouling the spring assembly for the fine tuning bolts- shown here with saddles removed.
    The new sizes and JT6 model are all on our website shop now, as well as our Reverb shop too:
    We now have a range of height blocks for the Floyd Rose Pro in stock too  as well as a wider range of sizes for the regular  Floyd Rose (32mm, 35mm, 37mm, 40mm, 42mm)
    We will add some standard thickness blocks in steel too for customers whose guitars wont accommodate a wider block without modification.
    edited October 2021 tFB Trader
    We have added some normal size (8mm thick) Floyd Rose sustain blocks but in Steel for those people who want the change of material but whose guitars won't take the bigger block or they have no wish to modify to do so
