Thanks. I understand it's worth, when doing the cavities, to put some shielding just to cover one screw hole of the scratchplate too?
How neat Should the cavity shielding be??!
It's like this so far
It's one big pickup cavity but finding the copper stuff hard to shape. Also found out the hard way via my finger that it's very sharp!!
Thanks. So either -1 or something like 0.2 is ok?
I've done more tests and it seems to start on -1 as soon as the terminals touch and then almost all over it goes to 0.2 after about 1 second
It's all done fine. Switch is in place but I have a problem with the pots...the hole in the scratchplate is too small for the screw part of the pot.
Any idea what size drill bit I'd need to drill the holes bigger?
Out of interest my new pickups came with a rubber spacer...where does that go? Is it underneath the scratchplate between the pickup cover and pickup?
It's a really useful tool to have for basic guitar work - there's also a really great unintended use which I find extremely handy... if you need to tighten a jack where you can't quickly or easily get at the back of it to hold, just jam the reamer lightly into the barrel and it will grip enough while you tighten the nut with a spanner.
