Has anybody attempted a Keith Richards Macabre build?
'Vot eva happened to the Transylvanian Tvist?'
  • KeefyKeefy Frets: 2341
    I thought Micawber was a blackguard Tele.
    It is. His Zemaitis is known as Macabre.
  • WezVWezV Frets: 16914
    No, but there is nothing too difficult there.
    I had a go at a zemaitis metal top style build which went okay but I didn't do brill on the engraving.   I made my own bridge and tailpiece in this style though.     I think this one is easy in comparison
    Thanks Wez. I was thinking about it as a first full build project.
    Would you want to make your own bridge... It's not too difficult
    With a little pro advice I might :) Also struggling to find a template for the body and neck.
    You have a full frontal picture, a known scale length and a standard dimension humbucker... Scale up.  ;)
    Ah ok, I had assumed spell check had intervened!
    Ah, there goes the easy road :)
  • MattNovakMattNovak Frets: 907
    I have a Zemaitis (Greco) which I took a template from, same (ish) body shape...
    www.theflyingacesband.com
  • @MattNovak That's perfect. What are you building?
    As with many things I build, it started off with a fairly clear idea but who knows what the end result will be. Its present state is here:
    https://www.thefretboard.co.uk/discussion/179686/zemaitis-bonabyrd-tele-type-thing#latest
    The above build has the lower horn rounded off a bit, but if you want a tracing of the original Zematis (including the correct headstock) I'll happily oblige.
    This is what its taken from:
  • @MattNovak I’d appreciate that, thanks. Drop me a pm? The build looks great so far. I’m also flexible on the finished aesthetic as long as it’s in the ballpark. What’s the Greco like?
    @Caffeine_Vampire, will drop you a PM shortly., am about to jump on a 9:30 call. The Greco is great, it has its quirks like the originals, Fender scale length (I think) and 24 frets... a bit like a strat neck on a small LP. I use it for Keef-style 5 string open stuff on gigs, hence the missing E above.
    Not usually into pretty woods, but some things call out for them!
  • Jez6345789Jez6345789 Frets: 1803
    Always love to see a bit of Zematis they have a certain something.
    How is the edge beading done is there a router bit that will do that will be tagging along
    Can't speak for the original, but could just be drawn on! Tony Zemaitis often took shortcuts. I heard a story about an added neck plate and screws to a set neck, as the customer had wanted a bolt on....
    One way to achieve a similar look easily would be to adjust the roundover bit to leave a ledge. @TTony has done something similar I believe, and it looks great. Or there's probably a contraption already made for a dremel so you could inlay some shallow wood binding.
  • TTonyTTony Frets: 27855
    Cheers @MattNovak !
    Yes, just a roundover bit sunk a little lower into the body ...
  • @TTony I don’t want to derail my own thread but that’s gorgeous, any more pics?
    Here you go.
    I had a bit of a blitz earlier in the year, and got these done ...
  • @TTony Mmmm... that doublecut is stunning :) Where are you sourcing your woods?
