almost I am waiting on delivery of a set of templates
A selection of diameters and lengths, most with bearings on top, but probably one with bearing on the bottom too. And a roundover.
For a first build you are probably not going to bind the body edges, for which you would need a special side cutter which has a smaller diameter bearing. You’re probably not going to make a neck either, for which you would need a bit to cut the truss rod channel.
Buy good quality bits. They cut better, and are less likely to damage the wood, or you. My everyday bits are Trend branded, and the important bits are from Wealden. I also have a burned out, chipped B&Q bit to remind me not to buy cheap crap.
for My first build I am making the neck and it has a bound body. I will end up with a guitar or a pile of scrap wood. I do fear the later is the more likely outcome but we will see
https://youtu.be/8K76CQFhrd0
