Flying V right handed body.
Neck routed to fit 56mm telecaster neck at fender tele scale (bolt on obviously).
single bridge filtertron route.
Drilled for a stoptail bridge.
telecaster cavity rear route.
There are some issues when trying to fit a Fender neck onto a Flying V or any Gipson body. Gibson necks continue into the body after the last fret, at least by the width of a pickup or more (SG). Look at the photo below a SG standard with 22 frets, if that was a Fender neck it would not be supported ether side by the neck pocket. There are 3 solutions to this, 1 the neck could be further into the body, although this would make access to the upper frets difficult. 2 you could extend the body outwards to support the neck either side, like a Les Paul junior single cut that has a small amount of wood running up the side of the neck to the end of the neck pocket. 3 have a standard Flying V neck but with a telecaster headstock and 25.5inch scale.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
